SL55/63/65/R230 AMG: Tire Pressure Monitoring End of Life
Old Jul 20, 2009 | 10:44 AM
blueSL's Avatar
SL55 AMG
I guess I have one of the oldest SL55's around, 7 years old in September.
Been getting a warning message about the tire pressure monitoring even though the pressures displayed are correct.
The dealer says the batteries in the sensors in the wheels are failing and I need new sensors, $800 for a set fitted.
I'm wondering if anyone else here is seeing the same problem?
Old Jul 20, 2009 | 10:59 AM
i_am_amused's Avatar
2004 S55 (SOLD, miss it every day), 2009 GL550
my '04 S55 just got its TPMS processor replaced (CPO). I can't recall the exact name of the part replaced, but it was the "brain" not the censors in the tires. It was constantly complaining about tire pressures but they were all reading fine in the dash. I did a reset (R button) as one would do after adding air and that really pissed it off. The unit failed outright soon after that, and I started getting "drive to shop" errors soon after. Dealer replaced the unit without asking any questions.
Apart from the "drive to shop" failure, this sounds exactly like the symptoms you are having. Now, this doesn't mean your censor batteries are dead, only that it could be something else.
Old Jul 20, 2009 | 11:21 AM
blueSL's Avatar
SL55 AMG
Thanks for that, I'm getting the "Visit Workshop" message too; it may be it is the control unit which has failed. Did they replace under warranty and if not, what was the cost? The crazy thing is that the repair cost is nearly double the original cost of the option.
The diagnostics for this thing seem quite poor and it would not be good to get the sensors replaced outside the dealership if the problem then turned out to be the control unit.
Old Jul 20, 2009 | 11:30 AM
IngenereAMG's Avatar
SL55AMG, Ferrari 348, Ferrari Testarossa, Ferrari F40, Ferrari Mondial t, Ducati 916, Indycar
My original set went bad after about 5 years and had to be replaced.
Old Jul 20, 2009 | 11:39 AM
it was replaced under CPO. Here's the line item from the invoice:
Performed SDS Test, found fault code B1349-001 (Check all wheel sensors). Checked battery life on all TPM sensors, all have more than 6 months battery life. Replaced TPM control module, performed programming, & cleared codes.
part number appears to be 002-540-75-45, description is "switch", and cost shown is 0.00
Old Jul 20, 2009 | 11:57 AM
blueSL's Avatar
SL55 AMG
Thanks for the extra information.
I understand the control unit predicts the remaining battery life and the recommendation is to replace the sensors if the remaining battery life is 6 months or less. Mine are all showing less than that. There's evidently a number of different error codes and, like you, I'm getting the "Check all wheel sensors" code in addition to specific failure codes.
I'm convinced this car is going to be a nightmare as the electronics age and we (collectively) get more gremlins. I'm sure most R230s will go to the scrap yard long before they are mechanically worn out.
I've decided to have the work done and just hope the control unit is not shot as well.
Old Jul 20, 2009 | 01:01 PM
BeltFedBob's Avatar
From: Lynnwood in summer, Fountain Hills during the rainy season in Wa.
2008 Maserati QP EGT, 2005 SL55AMG , 2002 CLK55AMG 2002 C230K Coupe
You can get the sensors for under $500 at Tire rack then any tire shop can install them and you don't need the dealer or shop to get them on line.
Old Jul 20, 2009 | 01:43 PM
i read somewhere that the sensors for one of the Ford models (pickup?) are the same as for some MBs, and at a substantially lower cost. Might want to search on that as well
edit:
found the post here
I have no idea if it works, but if it does it's a HUGE savings
Old Jul 20, 2009 | 08:23 PM
BeltFedBob's Avatar
Yes, but our sensors 03-06 are 315mhz.
I believe the tire rack price was $97 ea and the valve stem kit was about $12ea. If you don't need stems the saves a few bucks.
edit:
found the post here
Old Jul 20, 2009 | 10:14 PM
I was wondering what mhz the sensors are. Where did you find that info?
Still, $500 plus tire shop install fee is much less than $800 at the dealer. You should have enough left to buy some AMG valve stem caps
Old Jul 20, 2009 | 10:28 PM
BeltFedBob's Avatar
Because I just installed a set and I'm buying another set for my other wheels. I did my research with the OEM sensors.
Old Jul 20, 2009 | 11:33 PM
i see. thanks
Old Jul 21, 2009 | 04:14 AM
blueSL's Avatar
SL55 AMG
Thanks all for your responses. Unfortunately, here in the UK, there's less choice as TPMS is not mandated. I'm therefore over a barrel, so to speak.
Old Jul 21, 2009 | 10:21 AM
BeltFedBob's Avatar
I feel your pain brother. I just sent over 4ea 1/4x20x2 1/2" cheese head stainless screws to a buddy thet could not find them in GB.
I just ordered another set for $384.06 (sensors and stems) shipped. They will ship to the UK. If you talk to Todd 574.287.2345 x673 he can fix you up.
