SL55/63/65/R230 AMG: Where to buy carbon fiber trim SL55 06.
We can do the wood>carbon fiber interior trim conversion for $1500 (black carbon only, color carbon need extra material charge) with core exchange (we need your OEM trims back for next customer!)
Let us know if we can help! sales@dctms.com
you can even choose different color of carbon per your preference!
Picture showing 04 SL500 trim pieces in black and 06 SL in silver
We currently have one set of 06 SL65 wood trims coming back and ready to convert for the next customer!!
1 sand the trims to wood skin surface
2 lay the CF cloth on 2 sides together and compare the weave directions (this is the most difficult part)
3 thin layer of resin, check bubbles, wait for one day then sand
4 repeat 3
5 repeat 3
6 repeat 3
7 fully cured and polish
very easy to describe it, but difficult to do it, for step2, usually we need to try 2 times for left and right matching because when you try to adjust the symmetry the carbon weave will open up. the rest would be just skillful labor.
here is the work we made for member AMGFAN as carbon mirror housing on his SL65. This job is much difficult than the door panel but about the same for SL center console panel. The detail part is the corners but the flat surfaces!
Jon
