SL55/63/65/R230 AMG: Rooftop module for SL55 (Help!)
Hi guys...have any of you tried fitting a Rooftop Module to your SL's?
I bought a one from www.cabrio-module.de, and got with it instructions etc, but when i wired it up, i couldnt shut the car down or anything, so i disconnected it form the CAN BUS and just left it scared incase i did some real damage!
I did everything to the letter but it was asking for a red wire with a violet strip, and i found 3 of them, and tried every wire with no results...
I dont think i got the power to the module, hence why the car started to do funny things!
I dont know if all these modules are more or less the same, but if anyone has had an experience fitting them, your help would greatly be appreciated.
Thanks again guys
Kev
Thanks again guys
Kev
I installed one of that brand six weeks ago and it worked great! The only problem I had was to remove/open the CAN-connector. I had only one wire with red stripe, I have a 03 SL55. I wrote to Cabrio-Module to improve the part of opening the CAN-connector in the instruction.
I only had one Red wire with a violet stripe, and it was on top of the harness, I did not look any further so I cant say if there is more with the same coloring in my car.
Hi Kev i fitted one to my sl but i used the fitting instructions for the mods4cars module and it works fine it fits in the storage compartment behind the drivers seat i also fitted one of the same to my freinds sl and it took me 15 mins if you want the instructions for this fit email your email address and i will send it to you
Regards Mike
Regards Mike
Regards Mike
Regards Mike
Thanks for your help.
Kev
Hi mate.....na i didnt try it.
Im just gonna buy a smartTop one instead from the place that you put me onto. Seem much easier to install.
Frightened to do it incase i damage the car lol.
At least with the LED light on, ill know if ive done it right without hurting anything.
Cheers mate
Kev
Cheers mate
Kev
