SL55/63/65/R230 AMG: Want to change Transmission Fluid.. Can i use Royal Purple
Old Nov 17, 2009 | 07:35 AM
NikleinR6's Avatar
08 ML350, 2011 E550 Cab
I am going to do a complete oil change, and differential change. I thought while i was down there, i might as well change the trans fluid and filter.
I have used Royal purple products on other cars with great results. However, i have never used their MAX ATF fluid.
Royal purple's website says i can use the MAX ATF on Mercedes Benz 236.x
BUT then later states:
Please note: Max ATF is not recommended or an approved warranty replacement for: Aisin Warner AW-1, Ford Type F, Ford Mercon SP & Mercon LV, GM Dexron VI, Mercedes Benz MB 236.12 & 236.14, Shell M1375.4 (ZF 6-Speed AT) and Toyota WS. Max ATF is not recommended for use in any CVT applications.
So, what trans do i have in my 2004 Sl55, and can i use this instead of OEM?
Anyone else used it???
Nick
Old Nov 17, 2009 | 11:13 AM
Jon2007E63P30's Avatar
2007 E63 w/P30 and Eurotech CF Diffuser
This is the link to the oil specification cross reference based on transmission. I do not know the transmission you have, but the 722.6 is likely.
http://bevo.mercedes-benz.com/downlo...P-0231-01A.pdf
When you find which MB specification you should be using, look here.
http://bevo.mercedes-benz.com/bevolistenmain.php
Royal Purple is not on their list.
Old Nov 17, 2009 | 04:25 PM
YamiFanatic's Avatar
07 S550 & 05 SL55
ya stick to their list
i personally dont understand the hype behind royal purple but that is just me
there are many good oil companies out there
id suggest contacting a local mercedes specific shop that deals with modifcations and engine work
they will be much more helpful than the mb dealer
i personally race motorcycles and i run amsoil which is a smaller company that most outside of the enthusiast or racing world wont know about but they produce a top notch oil
Old Nov 17, 2009 | 07:46 PM
SL600 V12TT's Avatar
2004 SL600
AMSOIL
I currently use them for oil, 5w-40. LOVE IT! They might have the tranny fluid. Check them out.
Old Nov 18, 2009 | 09:50 PM
Quadcammer's Avatar
96 and 08 911 turbos
stick with mb tranny fluid for the 722.6 tranny.
