SL55/63/65/R230 AMG: Easy Entry
Old May 24, 2010 | 10:31 PM
krypto's Avatar
Easy Entry
I can't seem to figure out easy entry
I have it enabled in the menu..but the steering wheel doesn't move when I pull the key out.
Do I need to set the memory first?
Old May 25, 2010 | 07:18 PM
mdotpoker's Avatar
03 SL55,01 acura cls,05 lotus elise RIP
If the seat is far enough back or the steering wheel is already set high enough easy entry won't do anything.
Just to see where the threshold is do the following:
set the steering wheel as far down as it will go, then pull key. The steering wheel should go up.
Adjust the steering wheel up to see where it stops working
The same things goes for seat, sit the seat as close to the steering wheel as possible and see if it slides back once the key is pulled.
Hope this helps.
