SL55/63/65/R230 AMG: DIY: Removing side wood trim from door panels (R230)
Old May 26, 2010 | 06:54 PM
kamilclk430's Avatar
W215 V12TT Build by Speedriven, W221 S550 4Matic
Hey,
After a while searching on the forum for removing the side wood trim, I went and did it myself. I took some photos along the way, and after a while working on one side, the other side was a piece of cake when I already knew how to do it. I found it way easier with the windows down not too damage anything.
STEP 1 - Remove the inner silver/brushed trim from the door. There should be 6 screws holding this piece in place. One at the very top and one at the very bottom, so make sure you get them all.
DIY: Removing side wood trim from door panels (R230)-dsc06413.jpg
STEP 2 - Remove the little plastic SRS AIRBAG sign from the door. this comes off very easily. Twist it to the left as if unscrewing it and pull to get it out. When this is done remove the screw that is inside. Dont worry about it falling in there is nowhere for the screw to go.
DIY: Removing side wood trim from door panels (R230)-dsc06415.jpg
STEP 3 - Pull of the little triangle piece on the very top corner on the other side of the mirror. Simply pry it from the top and pull up on it.
STEP 4 - Start prying the clips off on the entire door panel. Start with the lower outer side and move your way accross the door to the speaker. Do the same on the side when you pull the bottom.
DIY: Removing side wood trim from door panels (R230)-dsc06416.jpg
STEP 5 - Now stand close to the panel and grab wide from the bottom of the panel and force/lift it up until it pops off. (MAKE SURE YOU pulled all the clips or you will end up braking a few)
DIY: Removing side wood trim from door panels (R230)-dsc06417.jpg
STEP 6 - There are a few little clips holding the wooden trim in place. Once you have the panel off you will see which ones, they are all the same. To take these off you will need a flat head screwdriver and simply put it on one side of the clip and twist as if you are unscrewing it, they should very easily come off. I tried pulling these off and damaged a few while doing so so the right way to do it is with a screwdriver.
THIS PICTURE IS TAKEN AFTER THEY ALREADY ARE PULLED OFF BUT IT IS THE SAME WAY TO REMOVE THEM WHEN THEY ARE STILL ON THE DOOR PANELS.
DIY: Removing side wood trim from door panels (R230)-dsc06418.jpg
Old May 27, 2010 | 10:56 PM
Rick SL55's Avatar
2005 SL55 AMG, 1986 Porsche 930S, 1996 Porsche 993tt
thank for the info!
Old May 27, 2010 | 11:12 PM
Originally Posted by Rick SL55
thank for the info!
No problem, the more info we get on this site the easier it will be for us all to do things with our cars.
Old May 28, 2010 | 06:05 AM
NikleinR6's Avatar
08 ML350, 2011 E550 Cab
This is a GREAT writeup..Thanks
Nick
Old May 28, 2010 | 06:53 AM
lippu70's Avatar
2015 mercedes E63 AMG, 2002 Rolls Royce LOL, 1997 Mercedes 300 TD
Thank you for the master piece.
Philip.
Old May 28, 2010 | 01:42 PM
no problem Guys
Old May 28, 2010 | 08:27 PM
damian155's Avatar
SL55
very detailed thanks. Are you changing over to CF?
Old May 29, 2010 | 01:51 AM
Yes I just made a thread on the new pieces.
Old Jun 23, 2017 | 07:14 PM
kennybui's Avatar
2004 SL 55 AMG
Do you guys know how much the 2 door trims and the center trim cost? I have the brown (wood looking) ones, I want to replace with the black ones. Has anyone had this replaced ?
Old Jun 23, 2017 | 09:32 PM
okbarnett's Avatar
Porsche guy who drives SL63 w/ perf pkg AND perf suspension
1200 to 2400$ for carbon fiber, if you want colors just paint them
