SL55/63/65/R230 AMG: seat movement upon exit
Old Jun 29, 2010 | 10:14 AM
azbenzguy's Avatar
2006 SLK350 2000 SLK230 Limited Edition Renntech stage 2 2003 SL55 AMG Renntech Stage 6
I've had my SL55 about a month. When I first drove it the steering wheel tilted up and the seat moved back upon exit. Now it doesn't. Anyone have any suggestions why this function quit?
Old Jun 29, 2010 | 10:31 AM
FLSL55's Avatar
SL65
If the seat is back past a certain point the easy exit will not activate.
If the steering wheel is set at a high point it too will not raise when you open the door.
Try moving the seat forward and the steering wheel down then open the door.
Also make sure the settings are correct in the computer setup in the dash.
Old Jun 29, 2010 | 10:38 AM
azbenzguy's Avatar
I checked the seat and steering wheel. I don't understand what you mean by "settings are correct in the computer setup in the dash". Any assistance will be appreciated.
Old Jun 29, 2010 | 10:41 AM
FLSL55's Avatar
SL65
In your onboard computer there are settings for the easy entry / exit feature.
Old Jun 29, 2010 | 10:47 AM
azbenzguy's Avatar
That part I understand. How do I find that feature? - Thanks
Old Jun 29, 2010 | 10:50 AM
FLSL55's Avatar
SL65
Now that would be way to hard to expain in typed words.....
Use your steering wheel buttons to find the feature. I think it's under "setup"
Old Jun 29, 2010 | 11:03 AM
azbenzguy's Avatar
J: I got it. Thanks - T
