SL55/63/65/R230 AMG: Vario roof not working? Might be your Trunk Flap. Easy Fix DIY
Old 05-01-2014, 02:06 PM
veraunc's Avatar
2003 SL500
my car has the new part installed, but flap still sags when top begins to open, could the arm attached to the flap be bent?
Old 05-01-2014, 09:41 PM
BGsBaby's Avatar
2004 SL55 AMG
Droopy Flap
The arm can be bent. If so it will break, that is what happened to mine. I found an independent who replaced the whole assembly, but not with a cable and tensioners, like the original setup. He said that was a "bandaid" that Mercedes knows this is a problem but there was no recall as it was not a safety issue. He replaced the cable with a rigid bar (not a cable) and new flaps. This permanently solved the droopy flap. The repair was about 1/2 of what the dealer wanted to replace just the cable and tensioners. I got the whole new assembly for less than $900.
Old 05-08-2014, 12:48 PM
Sg45's Avatar
SL 550
Quick clarification and pic to show issue
I am sure this is my issue! You can see in the pic I took the "arc" in the original part that is causing the gear to not engage (would be easy to mistake for a stripped gear but the teeth on both sides are perfectly fine!). Look closely and you can see the gear inside. That should be sealed.
HERE IS MY QUESTION:
I have searched a bunch on MB OEM Parts sites and the original part number (120448100) comes up as not found. When I type the one in from the pics in this post (2307500111), I get this description:
OEM Catalog SUPPORTING P
MSRP: $55.00
Your Price: $44.00
Before I hit order, can someone that's ordered these already confirm this is the right item and that this is for the pair!? It's clear that this is a failed part and I want to replace both while I'm doing it!
Thanks.
Attached Thumbnails Vario roof not working? Might be your Trunk Flap. Easy Fix DIY-img_3978.jpg
Old 05-09-2014, 11:25 AM
kittyandgary's Avatar
2003 SL55 AMG
You've got it - that's the right part.
Old 06-26-2014, 04:44 AM
zoslick's Avatar
SL55
I've searched parts.com but cannot find the part 2307500111... it says "No Matching Parts Found"... any ideas? I searched under "Part Number" and the Select Make: Mercedes Benz but still no results... can someone help? Thanks!
Old 06-26-2014, 10:04 AM
Sg45's Avatar
SL 550
This should get you the right part:
http://www.mbonlineparts.com/parts/2...?siteid=215843
Search for the part number: 2307500111
Old 09-02-2014, 10:19 AM
  #32
Tommyboy928's Avatar
89 SL500 Silver ,97 SL500 Carlsson 04 Mercedes SL55 AMG , 07 Mercedes SL55 AMG convertedBlack series
Anyone knows when Mercedes changed to upgraded parts for this issue with the flap ?
Old 09-06-2014, 03:07 PM
  #33
stykshooter's Avatar
SL 600
Mine started sagging couple weeks ago, got the parts (Ebay) this week & replaced, easy fix & works great
Old 04-23-2016, 11:04 PM
  #34
kiwigirl's Avatar
E350 coupe
Originally Posted by NikleinR6
Hi Thank you for this tutorial. I live in New Zealand and I would like this part however when i go to the parts.com website and put that part number in nothing comes up. I'm not sure where to look for the part on the website. Could someone send me a link please?????
Thank you in advance. My car is an slk350 2008
Old 06-19-2017, 03:37 PM
  #35
iammalibuboy's Avatar
sl55
Can anybody direct me to a thread to get at S69/1 which reports that the roof is in contact with the windshield? Need directions to remove interior windshield trim to get at the switch.
Quick Reply: SL55/63/65/R230 AMG: Vario roof not working? Might be your Trunk Flap. Easy Fix DIY
