SL55/63/65/R230 AMG: How to mod a stock sl55
Can I get some suggestions on what to do and who has the right parts that give satisfactory results. Should things be done in order? I thought about getting a pulley and ECU work done first, is there need for new intake and exhaust if I get that done? btw I'm from Toronto
Check Renntech,Kleemann,Evosport,Speeddriven.
Chassis : You can lower the car with a Lowering Module.
Wheels : Anything you want.
Body : CF Lip for AMG bumper, Decklid spoiler are the most common mods.You can upgrade your SL55 bumper for a SL65 one.You can also order a Brabus or lorinser bodykit (more rare)
Justin
Front mounted Heat exchanger and Intercooler pump can be easily Upgraded.
Justin
What is a good replacement pump that can be reliable for future mods?
The ECU tuning and pulley is where most start. We get requests for many different pulley sizes and match the software to the pulley, which is very important.
We lower these cars using the STAR system and/or links. Aside from improving the car's looks, it makes the handing much sharper.
We have found that the car's stock cooling system is adequate unless you are going above a 172mm pulley.
The Johnson pump is good, but the latest model OEM works well too.
Feel free to call or email with any questions.
Free OS X 10.6 RoadTest Simulation software :
http://www3.sympatico.ca/gmacgruer/Index.html
thanks
brad
Brad
Are the short tube headers for more torque, and the long for top end freeway kind of stuff? What's recomended?
Thanks...
(I have a "wife aceptance factor" problem when it comes to mods!)
Power Gains: +80HP*/85 FT-LBS.* with evo2.
Add the HE and you will get it in any weather.
Shorty headers are designed to work with the cats. If you eliminate the pre-cats you will pick up another 10-20 hp (and the same or slightly less torque).
thanks
brad
If you wana play, you gota PAY! "How fast do you wanta go?!?"
Seriously though, from what I've been reading, you guys do one Helluva job with these cars and I appreciate all your hard/fun work
Looking foreword to using your parts/services in the hopefully near future!
Thanks for listening,
Ray
