SL55/63/65/R230 AMG: WTB Lowering Links for 2005 SL55
Old Sep 27, 2010 | 04:43 AM
ToughSuccess's Avatar
2006 Mercedes Benz SL55 AMG
Hopefully someone out there is parting with theirs. PM me if you have a set for sale - thanks!
Old Sep 27, 2010 | 05:45 PM
mr Beenz's Avatar
s450
go with a lowering module instead.
Old Sep 27, 2010 | 05:56 PM
Viet_Amg408's Avatar
Pinto
GO TO WWW.ADJUSTABLEAIRRIDE.COM
ONLY 3 DOLLARS
Old Sep 27, 2010 | 06:10 PM
mr Beenz's Avatar
s450
the links tend to cause more problems with sensors, etc. than a good module like the V2 lowering module. Google it and see.
Old Sep 27, 2010 | 07:30 PM
Pinto
that maybe true.. i had links on my car for a while everything seems fine so far..
Old Sep 29, 2010 | 10:42 AM
bryanc4's Avatar
2006 sl55
adustableairride is top notch... we have used their links on many occasions and very happy.. easy to install too.... strongly recommend!
Old Sep 30, 2010 | 06:14 PM
AdrockTT's Avatar
SL65
I have not seen any evidence to support this personally.
I'll be doing links from adjustible air ride in the near future myself.
Old Sep 30, 2010 | 07:16 PM
Sunir's Avatar
SL55 AMG
SDS lowering is best...it's within the specifications of the system and lowers each corner respectively so that the wheel arch sits right around an inch above the tire. Plus you get an alignment with it which makes sure the car is spot on...grand total = $90 for lowering and alignment
You can see the result of this treatment on my car in the sig below.
Old Oct 13, 2010 | 08:25 PM
NEMES1S's Avatar
2005 SL600, 2016 ES300h, 2012 Hayabusa
I have a set if you are still looking, they are adjustableairride.com and brand new
Old Oct 13, 2010 | 09:23 PM
Cyan 740i's Avatar
SL55 Widebody
Sunir what is sds lowering???
Old Oct 13, 2010 | 09:34 PM
Tirreno's Avatar
SL55 AMG
That's the Star Diagnostic computer system shops like Mercedes use to update, adjust, ..., computer-based settings of the car. e.g. suspension height, temperature at which the fan will kick-in , etc...
The problem with adjusting the drop with the Star system, is that it can only go so far (not as low as with the ELM or links), and the dealer can (by mistake I'm sure) reset the height while they work on your car...
Old Oct 14, 2010 | 05:21 PM
Now that looks great! Do you know of any place I can get it done here in the bay area? Thanks for your help bro.
Old Oct 14, 2010 | 05:46 PM
Tirreno's Avatar
SL55 AMG
If you are in the LA or Orange County area, I'll point you in the right direction.
Old Oct 14, 2010 | 06:16 PM
The SL is in the bay - I fly down to LA for business occasionally - everyone who does anything on cars seems to be down in LA - no one does anything up here - and I'm here trying to help our economy spending money on unnecessary things
Old Oct 14, 2010 | 08:48 PM
Sunir's Avatar
SL55 AMG
I dunno about the bay area....I'm in MD. I would get it done at a dealership so they can align the car properly afterwards...
Old Oct 15, 2010 | 10:37 AM
NEMES1S's Avatar
you think you are far from aftermarket mb support....try living in Lincoln, ne....
Old Oct 15, 2010 | 09:47 PM
lol point taken
Old Oct 16, 2010 | 02:34 AM
NEMES1S's Avatar
I guess it is nice though as everyone that sees my car thinks it was waaaaaaaaay more expensive than I actually paid, and then they still don't know about the the v12 under the hood
Old Nov 11, 2010 | 08:27 PM
garyliew's Avatar
SL55 AMG
Hi Tirreno, I am in the Los Angeles area. Can you please share with me where I can utilize the SDS approach to lower my car?
Thanks,
Gary
Old Nov 11, 2010 | 09:10 PM
Tirreno's Avatar
SL55 AMG
Thanks,
Gary
Hey Gary, call Sam at Auto Talent: 310 877 8715.
Do understand that this method does not give you the crazy dragging look that others (Lowering Links or an ELM) can get you.
Having said that, I think it is still a nice drop compared to stock: At the front you end-up within 1' above the tire. For the rear you get 1'-1.5' above the tire. That's as far as the SDS will take you.
Using Lowering Links or an ELM, you can have the wheels slightly tucked under the frame, or leaving 1/2' above the tire for a smoother ride for example. There are just more options with those...
Let me know when you go there. I'll love to check out your ride and catch up.
Below are some pix of my car lowered with SDS. I since then went even lower with the Lowering Links.
Attached Thumbnails WTB Lowering Links for 2005 SL55-img_0419.jpg   WTB Lowering Links for 2005 SL55-img_0418.jpg   WTB Lowering Links for 2005 SL55-img_0408.jpg
Old Nov 13, 2010 | 02:53 AM
garyliew's Avatar
SL55 AMG
Thanks for the info and guide! I'll be sure to post some pictures after I have it done!
Old Nov 13, 2010 | 09:13 AM
cal1's Avatar
SL55, ML500 & Acura TL
Hey Sunir, how do you find the ride to be with Star lowering and 19s. I'm guessing you have some rough, uneven, potholed roads in Maryland like we do in Indiana.
Old Nov 13, 2010 | 10:36 AM
Gene Gorman's Avatar
05 SL55, 10 C63, 12 SLK3, 20 S560, 08Bentley GT Speed, 16 Aston Martin Vanquish
I'm lowered with links and running 19" wheels and it rides great.
Old Nov 13, 2010 | 12:36 PM
cal1's Avatar
Thanks Gene. Maybe I will have to get serious about a new set of wheels. I love the SL65 19" five spoke. i think they would look great on my car with its pewter metalic paint.
Old Nov 15, 2010 | 05:46 PM
Sunir's Avatar
SL55 AMG
SDS lowering on 19"s in my opinion is the best solution between a lower stance and still haivng a good ride quality over not the smoothest roads. More of this has to do with the sidewall thickness and stiffness of the tires fitted to the 19's...I think you'll like itm especially on factory wheels like the 65's
