SL55/63/65/R230 AMG: SL 65 Space Master Spare survey/question
The size is 175-50-19, and MBenz part number 230-400-1702.
NOTE: There is an 18 inch Space Master for the SL 55 available through dealer and parts.com.....part number 211-400-3195, but it doesn't work on 65 due to larger brakes. It is available for 55 owners if they need a spare through the dealer.
The 65 part is available in Europe for this car through Vredestein but not in the US, through their NJ headquarters warehouse. The Space Master is not sold in the US by their US branch and only can be obtained from the MB dealer according to them, which......see below....
Mercedes dealers have the part number in their parts catalogue, but it is unavailable with no units in the US....or special ordering available...
Mercedes USA will not order the item per their headquarters technical and customer service. Amazing since they still make the car for the 2011 year and the application works.
I was advised that Vredestein may make a special shipment depending on the interest.........so if any SL 65 AMG owners would like a space saver spare for an approximate price of $ 700.00, please advise.
Another option is to take firm orders to MBUSA or AMG and have them restock the part in the US and have it available through the US dealer network.
Another option is to call you local dealer and place an order for the part number and see if numbers alert them to supply this to the US. Explain to dealer that you would like to place an order without deposit to see if it is acknowledged without a backorder comment.
Thanks for response in advance as I continue on this odyssey to obtain a spare for my 65 for my longer trips........... Tire fit or fix a flat is a bad solution since it destroys the alloy rim and pressure monitoring system creating replacement costs for those items, plus the tire cost as they can't be salvaged even for a small puncture......the can also has a limited shelf life in your trunk at a cost of $ 153 to replace...
$ 530 plus shipping from California to NC after Germany
$ 900 plus shipping from Germany
Still would have been easier to pick it up from dealer for $ 700.00 minus Mercedes Club discount or $ 630.00 if they still stocked the part.
One time I ran over something metal in the middle of the night that I did not see at all and ripped my rear tire open on my Porsche C4S, so Tire Fit would have been useless and a flatbed was probably hours away......I was 30 miles from a main road in NC mountains at the time...
Having a space saver spare that time, gave me piece of mind knowing I could go on my way after the change, saved me time and money, and I was able to get somewhere near civilization about 100 miles away.....and get a new tire.....I deflated the spare and tucked it back in the trunk...used it one more time with that car and it still worked perfectly.......
There is a dealer order tag from Massapequa NY with different part number then on the wheel 230 400 1702 the wheel has 230 400 2702?
I posted a response to your question on the PL as well.
Give harrower a shout if you haven't already.
GL
EXECMALIBU - thanks for taking the trouble to pull the spare.....I read the inside of the wheel which was VERY helpful and that confirmed the 6.5X19 inch and ET 14 which is the info I am getting from Vredestein, European suppliers and Mercedes Europe dealers....I saw the last 4 digits of PN being 2702 on rim but 1702 on order ticket....interesting...
Thanks for all your help!!
Luckily my wife was not with me and I didn't have to have her hold it in her lap.
Sorry Karl G. - 230-401-27-02....correction
EDIT: Are you sure about this p/n? I found this eBay auction with the same number: http://www.ebay.com/itm/OEM-Mercedes...-/200487488793
May be a different part number for 2005/6 SL 65 due to 8 pot calipers in front to clear....versus reduction to 6 in the front in following years......don't know for sure....I spoke with V-stein directly on part number confusion after they advised me originally it was 1702..maybe both numbers work?
Unfortunately in the car......hopefully with no passenger aboard.....happened to me in my Porsche when I got a flat......temporary inconvenience.....
If you have a passenger, have to strap to the roof I guess.....I have stuff in the car to do that if needed.......
