Quote:
My mph difference was 24.33, and I had a 1.70 60' on 20" boat anchors.
SWEEET...Now throw some drag radials on there and beat that 11.40...once your car hooks it'll be all over for the current PBOriginally Posted by Benz-O-Rama
For a comparison of my tuned SL600, on my 11.40@120 run (Best ET, but not best MPH), I trapped 96.30 in the 1/8th, and 120.63 in the 1/4. For that run, my car had a base Eurocharged ECU tune.My mph difference was 24.33, and I had a 1.70 60' on 20" boat anchors.
Quote:
You mean like this? Brand new Mickey Thompsons are locked and loaded on 18" Rial wheels.
OOOOOH SNAP!
^^ Badass, my friend. Love seeing guys keep pushing the envelope
Ok...regarding the thread issue...I have an update.
Day 1 in the shop revealed low Fuel Pressure of barely 52psi. Not only is this below the low/mid 60's that Marcin wants to see on the car, it's also well below MB's minimum spec. Obviously, not enough fuel pressure can cause a host of power issues....
Getting it corrected this week and then on the dyno...busy week since the car's also getting motor mounts, tire pressure sensors and the ABC was apparently near death! Amen for warrenty - woohoo
Stay tuned for results.
Hopefully that resolves everything! Good luck! Originally Posted by Philly Single
Tom
Quote:
Tom
Thanks Tom!Originally Posted by TMC M5
Hopefully that resolves everything! Good luck! Tom
Another update. SDS found a miss in cyl #6 too. Personally, I never felt it and thought the car pulled decent. However, seems like I had/have two things working against me.
So, fuel pressure will get sorted out this week as will the #6 miss - THEN dyno.
Stay tuned.
What's the fix for the fuel pressure? New pump or **gulp** all new injectors?
And are they just putting a new plug or coil pack for the #6 miss?
Good luck with all of it, hopefully you get the results you are looking for. Did that misfire kick on the cel?
Hey guys -
The injectors looks good...not positive of the plan of attack, however, I've run into a few other MB owners who had to have fuel pumps replaced more than once. So, I'm guessing will require either new pump, new fuel ecu...both...stay tuned.
Regarding the miss...well...the car had the plugs done about 10k miles ago. Think we're leaning towards a new coil pack.
NEMES1S - ha...nope, no CEL for the miss!! After all the new parts it's getting...damn well better get the results we're looking for
ExploreCongrats!
I never knew EC offered a tcu tune! Did you have to take the tcu out of the footwell and send it out, or was it done another way?
Quote:
I'm posting because I recently upgraded my EC tune in my 600. Not sure how recent your tune is, and it sounds like you are talking with Jerry, but I have Jerry's recent ECU tune (November) and also his new TCU tune. While I went through a few ECU versions to get the combo dialed in, my car is notably faster than what they were doing with the ECU last Summer. I have not been to a track yet to validate with numbers, but I am pulling like a freight train in 2nd and 3rd with colder weather.
If I were you, I'd put the car on a dyno asap to see what is going on.
Originally Posted by NCE500
It appears you have gotten a lot of good advice here.I'm posting because I recently upgraded my EC tune in my 600. Not sure how recent your tune is, and it sounds like you are talking with Jerry, but I have Jerry's recent ECU tune (November) and also his new TCU tune. While I went through a few ECU versions to get the combo dialed in, my car is notably faster than what they were doing with the ECU last Summer. I have not been to a track yet to validate with numbers, but I am pulling like a freight train in 2nd and 3rd with colder weather.
Quote:
Is this at idle? Also, do you know where they tapped into the fuel rail?Originally Posted by Philly Single
Quote:
Yup, that is at idle. Other than the passenger side fuel rail - I'm not exactly sure :/ I'll try to get some better details...Originally Posted by the head
Jay
Quote:
Originally Posted by Max.H
Glad to hear you figured out the issue.
Yeah...hopefully! Slight delay since I need to get the warrenty guy over to green light all the parts getting bought. But should have the fuel pressure and spark issue done and on the dyno by next Friday.
Arent new injectors (or coils??) on the v12tt something like 4 grand??
big bucks for big power!
Ha...well, the injectors seem to be just fine. I think each coil pack is around a grand or so. But yessir...pay to play...warranty is getting hit for just under 4g's + labor.Originally Posted by Sunir
Jay
Hello Gents -
Wanted to update this thread to see if 1) SS2Z06 had any update and 2) to provide my own.
Well, after many weeks...I think I finally have a good bit to report on.
Like SS2Z06, I was having a hard time getting my S65 to run the numbers like the other guys were seeing here on a tune. My best run was 11.8 @ 119. Finally, I took the car to John at Broadway Performance in Passaic, NJ.
The idea was the just check the fuel pressure and see what's up...well...he found the following issues:
1) Fuel pressure was ~52psi, out of spec and way below what Marin has seen on S65's. New fuel pump was installed.
2) Car had a miss in #6. This did not throw any CEL's, but showed up on SDS. New coil pack was installed.
I believe those are the only two "performance oriented" issues. However, we also replace all 24 spark plugs. Additionally, the motor mounts were shot, replaced those.
Side note: my ABC was leaking - so all sorts of things were replaced there too. New set of air filters put in as well.
I had logs of the car's performance from BEFORE all of the above was done and the car would pull (2nd gear) from 1985rpm - 5170rpm in 3.38seconds. This was the same state the car was in when it went 11.8
I made a few pulls AFTER John got done replacing everything and it would do the same 2nd gear pull from 1985-5170rpm in 2.98seconds. The car felt good, but not "ridiculous". Problem was still around boost. The caw clearly running better and harder but would still only hit 23.5psi at most.
Marcin and I went back and forth on a few tunes and the one I have on the car now has seemingly addressed the boost issue and the car officially feels ridiculous. Car will now hit 26.3psi and hold boost higher & longer. This past weekend it made the 1985-5170rpm pull in 2.50seconds.
More interesting facts, the following is the average boost:
Before Broadway Tuneup avg: 19.55psi from 3680-5150rpm
After Broadway Tuneup avg: 20.56psi from 3680-5150rpm
After tuneup w/new SD tune: 22.69psi from 3680-5150rpm
And since everyone likes graphs...I think the following really shows the differences:
Much stronger! It'll be interesting to see your track numbers.
Much better
There's an MIR track rental this Friday.
I'm so happy it's running hard for you Jay! Enjoy and stay safe.
See you soon.
See you soon.MBWorld Fanatic!
Great news! It is so depressing when your car isn't running right. I am glad things got figured out and it is back to being a beast!
Tom
Tom
Hey guys -
I'm excited to get to the track as well, Atco opens up in two weeks or so. Ha, I'd love to hit MIR - but the 3hr ride from my house is killer :/
I'm also looking forward to the Spring release of MT's new 19" drag radial
Tom - you said it man...very frustrating! Luckily John @ Broadway treated the car like his own and dealt 100% with the warranty company to get all the OEM stuff straight. And Marcin / Jo @ Speedriven provided alot of support and things to try. And, of course, the new tune.
Marko - Thanks for help via PM, I would've thought a car like this would throw a CEL for anything out of the ordinary...guess not.
OH - since the car was in the shop anyway, I got Marcin to whip up a remote mount IC tank for the trunk and John put it in. Stay tuned for pics - granted, it's still pretty cold here in NJ...but I know it's going to pay for itself once it gets hot out there.
Next stop...big IC's and turbos...
Jay
Jay
How did you get a boost reading? Was that listed under the OBII scanner as a parameter? Log works did not show a boost reading that I could find. Thanks.
Quote:
I got a boost reading right from the OBD port via LogWorks. I choose MAP on the OT-2 tab, I forget exactly what unit of measure it would display in on the iPhone. However, when examining the logs with the software on my laptop - I went to Configure Channel / MAP and set the conversion 5v = 29.4psiOriginally Posted by Stephen04E55
Jay
