SL55/63/65/R230 AMG: SPEEDRIVEN | V12 Turbo PKG
Old 01-14-2011, 06:17 PM
  #51
Speedriven1's Avatar
Speedriven
This is something to keep you guys from killing yourselves over the weekend. Response is good, but boost shown is only 18 lbs., so there's still a bit of a ways to go.
More to come next week (weather permitting).
(also: W215 CL600)
Old 01-14-2011, 07:01 PM
  #52
halm's Avatar
2005 SL600 OETuning ECU
With regard to the weight issue, I thought that in terms of SL55 v SL600, the V12 is only a 100 lb penalty (4400 v 4500). So not that much of a difference.
My research says that E55 weight 4200 lbs
Old 01-14-2011, 07:26 PM
  #53
EXECMALIBU's Avatar
SL65, 427 COBRA (CSX-3127)73 911S, 246GTS (DINO SPYDER), CORNICHE,1962 PORSCHE TWIN GRILLE ROADSTER+
The SL65 V12 engine is only about 60lbs heavier! The car only weighs 160lbs more!
If you think the SL65 V12 engine is a lot heavier that is a myth! The engine weighs only about 60lbs more then a SL55 engine... Granted the 60lbs is in the wrong place being up front...
Take into account the entire SL65 only is about 160 lbs heavier then the similarly equipped SL55!
The entire SL65 drivetrain is beefed up and they all have full options (heated/cooled seats etc) and full leather on every part of the car which is heavier the vinyl... Plus remember the SL65 has the following:
1. Limited slip (30lbs)
2. Much larger (enormous)brakes (25 lbs)
3. Heavier axles and drive shaft, (15 lbs)
4. Extra inter-coolers (2) (10 lbs)
5. 19 inch wheels (10 lbs)
Just to list a few items... Add up all of the extra weight of these SL65 only performance items and you will realize that the extra 160lbs of weight is spread out over the entire car...
Old 01-14-2011, 08:36 PM
  #54
V12Godspeed's Avatar
Your worst nightmare...
(also: W215 CL600)
That is very impressive with just 18psi, When I had the VRP825 package it was hitting 29 psi of Boost and peak of 30's...of course it was only laying down close to 700 rwhp...
Old 01-15-2011, 06:54 PM
  #55
NEMES1S's Avatar
2005 SL600, 2016 ES300h, 2012 Hayabusa
I thought it was awful, but that is pretty substantial for 18psi, looking forward to big boost
Old 01-17-2011, 10:26 AM
  #56
Speedriven
Me, too! Only so much boost you can make on 91 octane, and we're easing into it on this particular car (the fact that the weather isn't playing along doesn't help - lots of snow delays).
More dyno graphs later in the week.
Old 01-17-2011, 11:37 AM
  #57
Speedriven
Originally Posted by Thericker
Forget the Dyno's... Just please ask Marcin these simple questions thank you.
1. the max boost the turbos will put out is 25+, but on pump gas tune we're going to keep it in the low 20s.
2. this is our "premier v12 tuning pkg", from our site: http://speedriven.com/products_pkgs.html
SPEEDRIVEN PREMIER V12 BITURBO PKG
800 + HP PERFORMANCE PKG
This is the big one. Delivering over 800 hp from a smooth, reliable, daily-driver that retains all the class and character of Mercedes' flagship V12 cars. This is the package that will bring tears to the eyes of everyone who drove the original AMG Hammers and dreamed of driving a big-bore Mercedes-Benz on the Autobahn at break-neck speeds in quiet, Teutonic comfort.
Speedriven's premier V12 Biturbo tuning PKG outperforms even in the mighty SL65 Black Series, with all subtlety of the original, legendary AMG Q-ships.
- 800 + HORSE POWER ULTIMATE BOLT-ON PERFORMANCE PACKAGE
- CONSISTENT HIGH-TEMPERATURE PERFORMANCE
- EVEN MORE HORSE POWER AND TORQUE
- IMPROVED THROTTLE RESPONSE
- QUICKER, FIRMER SHIFTING
- SPECIAL PKG PRICING
Old 01-17-2011, 04:12 PM
  #58
Thericker's Avatar
V12-Biturbo
Thank you Jo! Ultimately shooting for both a street tune on CA **** 91 + Race tune on 109 via your Tune-switcher gadget
Old 01-17-2011, 04:30 PM
  #59
Thericker's Avatar
V12-Biturbo
Yo bud! Keep in mind the car used to make that Dyno above has ZERO exhaust work IE DP's full 3"/Race or NO cats etc = EZ 25 + rwhp will prolly loose 1 psi after exhaust work & = near 600 rwhp on 17-18 psi, 25 psi will add 7-8 lbs boost, each psi is worth a conservative 10hp it's adding up nicely
I know you're NO stranger to boost this pkg is looking good..
Old 01-18-2011, 08:23 PM
  #60
Former Vendor of MBWorld
MBH motorsports's Avatar
C63, SL55, E55, CLS55, ML63, C55
Speediven was on the dyno again today. Don't know what the results were, but I'm sure Jo will be along to share them with you guys.
Old 01-21-2011, 09:51 PM
  #61
OUTCAST's Avatar
SLK55AMG, SL600
Nice work guys keep it up!
Old 01-22-2011, 11:35 AM
  #62
NEMES1S's Avatar
No new dyno yet?
Old 01-24-2011, 04:26 PM
  #63
Sunir's Avatar
SL55 AMG
max boost of 35 psi = how many BAR? Also will you be controlling boosting charecteristics with an on board EBC?
Old 01-24-2011, 04:31 PM
  #64
blackbenzz's Avatar
haters crazy
~2.38 bar
Old 01-24-2011, 04:36 PM
  #65
Sunir's Avatar
SL55 AMG
Originally Posted by blackbenzz
~2.38 bar
sorry I mis-typed I meant 25 psi? As Jo indicated for his kit...
Old 01-24-2011, 04:51 PM
  #66
Speedriven
We were running out of injectors. Back to work on the car last weekend after making just about 750 hp - once the new injectors are in we should be good.
Old 01-24-2011, 06:37 PM
  #67
NEMES1S's Avatar
I kept thinking fuel would be an issue. Just because I haven't checked, do 600's and 65's have the same pump and injectors?
Old 01-24-2011, 06:38 PM
  #68
Speedriven
A. they do not, the 65s flow more.
B. I am not 100% sure that this is an issue on ALL 600s, rather than just THIS 600, you know? The new injectors should get here in the AM, and we'll have some results.
Old 01-24-2011, 08:29 PM
  #69
ratedx's Avatar
2005 sl65
sl65 new owner
thanks joe/speedriven for taking time out to explain ecu ugrade for my sl65-it is completely stock w/5500 miles what performance should i expect? any youtube video for ecu update compared to stock sl65? thanks again
Old 01-25-2011, 06:24 AM
  #70
AdrockTT's Avatar
SL65
Just a standard conversion for all PSI: BAR = 14.7 PSI:1 BAR
So 25 PSI = 1.72 BAR
Old 01-25-2011, 03:29 PM
  #71
NEMES1S's Avatar
What are the specs/brand on the injectors you are going with? how much bigger are they than stock?
Old 01-26-2011, 03:32 PM
  #72
Thericker's Avatar
V12-Biturbo
Is that 750rwp or Crank?
Old 01-26-2011, 04:40 PM
  #73
blackbenzz's Avatar
haters crazy
That one has clogged injectors?
Old 01-26-2011, 04:53 PM
  #74
Speedriven
It still had the old fuel filter, which has been updated by MB. On the 600s, the old filters also had a pressure release. A few ways the fuel delivery might not have been 100%.
Still waiting on UPS, guys.
Old 01-26-2011, 04:54 PM
  #75
Speedriven
Crank on pump gas.
Quick Reply: SL55/63/65/R230 AMG: SPEEDRIVEN | V12 Turbo PKG
