SL55/63/65/R230 AMG: SPEEDRIVEN | V12 Turbo PKG
#77
sl65 newbie needs more hp
hello jo-other then ecu update what would be some other hp products that would gain more hp? We have 93 octane here in nj-also would it make sense to change out air box/mods? thanks for your help
#81
#82
speedriven mods
i just want to personally thank joe and marcin at speedriven for doing an excellent job. i recently had the ECU, TCU, and probably the best cat-less exhaust known to mankind for the W215 V12. i also had the v2 lowering module installed and the car looks sick dropped. cant wait for spring to put my kleeman ts6s on. the intercoolers and turbos are on my short wishlist.
again, i highly recommend everyone to get these mods... great price and great people to work with.
#84
I would really like to know the final numbers, because from what I have read the VRP825 package produced better numbers and also cheaper compared to the new package. VRP825 produced 700 rwhp = 875 crank Hp (with 20% loss from driveline).
will the new bigger turbos and the much higher price produced 800rwhp? accounting for the 20% driveline loss thats 1000 hp at crank. I am doing a lot of saving hoping to get the VRP825 but if the bigger turbo package delivers then I will save some more
I would love to see Speedriven take the record from Renntech for the fastest CL65 without using nitrous or meth,
#85
V12-Biturbo
The new Speedriven pkgs will deliver, I have the permiere pkg on order.. VRP is disolved so that's not a viable option anymore, also those results were on 30 psi, w/ms 109
The new larger Turbo kits will make 800 rwhp on 91 pump @ ONLY 20 psi, NO comparison really
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
#87
After the package get installed what else are needed to keep the vehicle longevity?
New Engine/Transmission Mounts?
Fuel - bigger bumb - bigger injectors - fuel rails?
Air - intake?
intercoolers upgrades?
Limited Slip?
Transmission upgrades?
Drive shaft/ Half shaft?
Wider Tires + Wheel spacers for wider tires for better grips?
Speeding ticket Funds?![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
I just want to know what are all need to have a complete upgrade to handle all that power and torque. Thank You.
Air - intake?
Limited Slip?
