HELP: IPOD INTEGRATION FOR '05 SL55
Subscribe
Dec 23, 2011 | 03:14 PM
Hi all - i would like to have an ipod connector in my 05 SL55 - can anyone advise me on how to go about this - i dont want an FM modulator - i want it hard wired to the car where i will be able to use controls from steering wheel and actual head unit. thanx
Reply 0
Dec 23, 2011 | 04:25 PM
try this: http://www.dension.com
Reply 0
Dec 23, 2011 | 04:32 PM
Thanx
Reply 0
Dec 23, 2011 | 05:50 PM
Quote: try this: http://www.dension.com
+1
Reply 0
Dec 24, 2011 | 12:01 AM
or the mObridge or iTronic
Reply 0
Dec 25, 2011 | 02:04 PM
Quote: or the mObridge or iTronic
Ready to purchase your Ipod solution couple of Questions 1st, will my Iphone connect to it? It has built in Ipod that I've stored my music on.... Lastly when I went to your site it shows S class picture when I choose my 2005 SL600 model car?
Will it be turning off my Navigation as well as my CD stacker? Description basically states it takes the place of current CD stacker behind seat. What's w/Navigation questions? Will it be turned off while using Ipod too? Thank you!
Reply 0
Dec 25, 2011 | 02:59 PM
We just show an example MB, not each model
It will work with any Apple product or android or ???...
It ha no effect on Navigation, but functionally replaces the CD changer. The single cd still works too.
Reply 0
Dec 26, 2011 | 05:54 PM
Thanx for quick response, last Q from studying the wiring diagram it appears the Ipod/Iphone/etc needs to be WIRED w/actual cord & connector? So everytime I want to use Ipod etc I need to plug my Iphone/Ipod into this cord?
Reply 0
Explore
Dec 26, 2011 | 06:59 PM
Not if you use Cartronics Anystream. It let's you connect your iPhone/android via a Bluetooth connection. It's the exact way I'm going instead of installing Sat. With the iTronic and Anystream, you can wirelessly stream anything from your phone.... Love that.
Reply 0
Dec 26, 2011 | 07:30 PM
Quote: Not if you use Cartronics Anystream. It let's you connect your iPhone/android via a Bluetooth connection. It's the exact way I'm going instead of installing Sat. With the iTronic and Anystream, you can wirelessly stream anything from your phone.... Love that.
Not sure Anystream will work on my 05' SL as it DOESN'T have the aux jack port in the glovebox or center console, unless it's underneath in the wiring buried or behind actual headunit? I'd def take Anystream route if I could find this port to hook into
Reply 0
Dec 26, 2011 | 09:09 PM
The iTronic WITH the Anystream is what Vabene7 was talking about. You are correct, the 05SL does not have an Aux jack. However, if you install the iTronic, you have lots of options.
Reply 0
Dec 27, 2011 | 02:48 PM
Quote: The iTronic WITH the Anystream is what Vabene7 was talking about. You are correct, the 05SL does not have an Aux jack. However, if you install the iTronic, you have lots of options.
Ahh understood thank you! Ordering soon, where would you recomend Install in LA, CA. area? Or is Install truly Plug n' Play?
Reply 0
Dec 27, 2011 | 03:19 PM
Both- we can connect you with an installer, you can plug it in yourself!
Reply 0
Dec 29, 2011 | 03:12 AM
Ricker,
The guys at Cartronics told me when I buy the iTronic and Anystream, they will personally walk me through the install of pulling the Comand head unit out to pug in their iTronic module. They also told me it was a pretty easy install and I should try it with their step by step instructions over the phone......maybe that can be an option for you......
Reply 0
Dec 29, 2011 | 08:18 AM
We love to that for people - frankly it feels good to help someone do it themselves - brings a sense of accomplishment for both of us!
Reply 0
Subscribe
Currently Active Users (1)
