SL55/63/65/R230 AMG: How is your early SL55 AMG?
Under a side bar "£15k Villains", they say this about the car: "The problem for today's buyer is that it's a horribly complicated car, with trick anti-roll suspension (including computer controlled spring platforms) and a space shuttle's worth of electronics. The result is a constant stream of expensive problems and our advice is to steer well clear".
A fair or unfair assessment? My Sept 2002 (MY 2003) SL55 has hardly been a paragon of reliability even though it has covered only 18k miles and has suffered hydraulic leaks, total brake failure and various squeaks and creaks. The areas where hydraulics meet electronics are a predictable minefield.
The car did move the game on when first introduced with much more electronics than before, something like 47 separate control units and it's only a matter of time for us all before something needs replacing - expensive not just in terms of obsolescent parts but the time taken to locate the problem with the rudimentary diagnostics which were standard at the time the car was first designed, starting 1998.
So... the question is, if you have an early SL55, how many miles has it covered and is it proving to be a maintenance nightmare?
[The other villain they speak of is the Aston Martin DB7 which I can imagine is a real horror. At least the SL doesn't rust...]
Mine is fully loaded (pano, distronic, Parktronic, keyless go, phone,etc...) and is a beautiful car that runs fantastic!
In terrms of if it is a good buy, if you can stomach the repair costs then what other hard top convertible with about 500 HP is available anywhere in the same range? Nothing.
Z
Mine driven only 42' km with no problem.
It's the most beautiful cabriolet with the best sounding engine out there, and you live only once. Take the deprecciate hit, repair cost and take good care of it, and you have a dream car that you'll cherish as long as you have it.
I'll bet you would lie awake in the night regretting it if you sold it.
It all comes down to "if you gonna play you have to pay", i'll anyway gonna keep mine forever :-)
Mine currently has 71,000m 2003.
ABC problems around 57,000m,
gas tank baffle around 65,000-
pulley 68000m
PSE pump 47,000
But I must say when everything is working you will love the car.
pulley 68000m
PSE pump 47,000
2x airpump relays (inc one supposed to be modified).
1x airpump. (but after the last relay went another airpump is needed)
1x Alarm sensor
now the bit that really hurts is 3x 19" split rim wheels, they start making a loud clicking noise at the split, and I fully expect the 4th original to go the same way.
1x CD changer.
1x Climate control computer.
If it wasn't for the wheels I would say I would have been happy with the damage so far, AMG weren't interested in helping with the wheels in anyway.
As I always says, cars are built to be driven, not parked, so you out there use it as often you can.
In the end of last season I got problem with the Left headlight that doesn't lit up at start, I think one of the control units in the engine bay has to be replaced. That will be sorted out April 2nd when it's out of winter storage.
Can't complain on that, a car that is so advanced in all aspects, and far more beautiful then the new R231
1. AC compressor
2.Starter
3.Radiator Fan
3.Front and rear battery
4.Secondary Air injection ( I think I got fu@#K by the dealership) just a relay would do
5.EIS
6.IC Pump (thanks to forum member here)
7.Trunk flap ( Thanks to Nick forum member here)
8. CD Chnager is fu@#K up too haven't fix it yet
so far from what I can remember but i do enjoy every moment driving it
just bought it last year in july
which has very low mile only done 17590 when i pick it up
from that
it just had a keyless go computer replaced
cost $4000usd included labour from the dealer
the dealer provide one year warranty for it.......
so far only this things happen in my car............
I have had the following problems:
1 - Alarm sensor failed
2 - The apparently all too common "baffle in the fuel tank coming loose" I have not had the tank replaced as it costs around £1500. It sounds like a tin of paint rolling around in the boot. I used to be able to get over this by turning up the music. I cannot do this anymore, however, as:
3 - The CD changer has stopped working.
4 - As I write this reply my SL55 is in the garage having all the suspension joints replaced at a cost of £1000.
It looks like mine has suffered the same problems as many other owners and has cost a few quid BUT.... I love the car and wouldn't change it.
1x Alarm sensor
1x CD changer.
I have 2003 getting ready to turn 60,000...
- at least 3 trunk batteries
- I/C pump
- last year (about 5,000 miles ago) ABC pump
- about a month later ABC front lines
My biggest gripe(expense) is the ABC suspension repair cost the rest isn't that bad & I have at least doubled the repair cost in mods now...
I won't be getting rid of mine either & I would do it all over again in a second... no other car like it PERIOD
2005 that I purchased with 76K miles on it for $29K. Owned it for just under a year when the Supercharger decided to let go which in turn shot metal shavings down into the engine.
So $10k later I will be picking her up tomorrow with a 40K mile engine in her....
Good thing I put $7K away for my "warranty" so really only 3K out of my pocket??? lol ;-)
Can not wait to drive
her again and it will be getting warm again soon!!
I've had to do:
ABC repairs
Engine mounts
Trunk latch
Command unit
Heat exchanger pump
Coil packs
High voltage ignition
Gas tank (baffle went out)
If you can find a used SL with these common issues resolved, then it might be a good deal.
her again and it will be getting warm again soon!!Buddy, you have had the worst possible luck of anyone I have ever seen.
Here is hoping your new engine gives you 100k of enjoyable trouble free miles.
