SL55/63/65/R230 AMG: Question about SL65 rotors 16"
I don't know if there is an aftermarket 65 rotor available....I believe EVOsport was to develop one, but not sure......
You'll have to search around a bit to see....
Originally 65 had 8 pot calipers and changed to 6 pot in the front in 2007...
Rear rotors were about 14 inches plus and expensive.....4 pot calipers....
I guess I have to accurately measure what Renntech states a 16" .. 390mm = 15.4" .. also the Renntech calipers are 8 pistons but they look slightly different than the AMG ones , I know they are Brembo but they are what Brembo refers to as the G model caliper.. I am mentioning that because I am sure the brackets they used are to set up the caliper for a 16" rotor , using a slightly smaller rotor will misalign the rotor to the caliper .. right ? Also , my car is a W219 CLS55 .. would the hat/rotor assembly work for that given the offset , Thanks, Max
See below link for more info:
http://www.evosport.com/product/prod...VO.BRK.M39.RF1
