SL55/63/65/R230 AMG: NPB
Old Nov 13, 2012 | 11:31 AM
kustom2k1's Avatar
03SL55
NPB
Can't let the E55 guys have all the fun. Nitto/18s DRs hook
https://www.youtube.com/watch?v=c0Izjq-IVVo
Old Nov 13, 2012 | 11:22 PM
RonnieRenaldi's Avatar
SL55 AMG & BMW F10
Nice!
What's your launch technique?
Old Nov 14, 2012 | 11:17 AM
kustom2k1's Avatar
03SL55
RR, after the burnout I roll it slowly to stage, helps bring IATs down. Once I trigger the second staging bulb I slowly bring the revs up to around 850/1050 by the time Im on the last bulb I try and flash the converter by stomping on the peddle while disengaging the brakes. You want to be progressive. My 60s suffer if I bring the stall up to 1200 and hold it there waiting for the green light. Point is to flash the converter.
Old Nov 14, 2012 | 11:55 AM
SL55 AMG & BMW F10
What converter are you talking about?
Old Nov 14, 2012 | 12:06 PM
kustom2k1's Avatar
03SL55
The torque converter in the transmission.
Old Nov 15, 2012 | 12:47 PM
overZealous1's Avatar
sl55 amg
sweet! can't wait for tracks to open here again!
Old Nov 15, 2012 | 02:01 PM
kustom2k1's Avatar
03SL55
Not many SL55s running OZ, would be cool to have another SL55 running some good #s.
Need to get my hands on an 82mm throttle body and I'm done.
Old Nov 15, 2012 | 05:32 PM
sl55 amg
i am close to firing my car up, and will let you know how the audi one does. i am not expecting to have any probs with it as many have used it before.
Old Nov 15, 2012 | 06:17 PM
kustom2k1's Avatar
03SL55
This is a mod where we can keep costs low, considering how much vendors ask for an 82mm kit. Plenty of guys running Audi and Porsche TB with little to no issues. I've got my eyes peeled for one.
Old Nov 16, 2012 | 01:05 AM
amx1397's Avatar
05 crossfire w/SL55 drivetrain installed by Rudy Compart Intake/Needswings best et-10.76 @ 129
I was there that night,, after that run,(which was a hemi charger he was running) later when he was in staging, no one would get beside him, it is bad when no one will run you. jim
Old Nov 16, 2012 | 10:04 AM
kustom2k1's Avatar
03SL55
LOL, Jim you spin a marvelous tale. I don't think anyone else was there.
Next Wed looks like good weather Looking to run the race gas tune.
Old Nov 16, 2012 | 11:37 AM
sl55 amg
there was a few audi tb's on ebay when i was looking for mine.
Old Nov 16, 2012 | 11:47 AM
kustom2k1's Avatar
03SL55
OZ, do you have a part number for the Audi TB?
Old Nov 16, 2012 | 12:02 PM
sl55 amg
here is one. looks like it might have a crack in the connector, but you would be using the one off your mb tb anyways.
http://www.ebay.com/itm/THROTTLE-BOD...sories&vxp=mtr
another
this is the company i purchased from
http://www.ebay.com/itm/Throttle-Val...sories&vxp=mtr
i did a search for the audi a8 throttle body. but, basically anything that had the 4.2 v8 is the correct one. i bumped a thread in the e55 section that had all the info you needed to do the wire swap about 1.5 weeks ago.
i can show you what i did for the egr. while the hoses are big coming from the egr off the valve covers, the inside hole is less than 1/16" dia. i just spliced in an air compressor air filter with 1/4" hose ends and routed back into an open port i had right after the tb. since i changed the flex hoses, i couldn't hook up the fresh air portion of the system either. i just purchased a 3/4" mini filter to hang off the stock tubing.
shardul has the weld on adapter plates. i was able to wrap up the entire project for around $225.
Old Nov 16, 2012 | 12:15 PM
kustom2k1's Avatar
03SL55
Thanks OZ, once I buy the TB I'll be in touch. 225 is chayeep considering the 20/30 HP in possible gains.
Old Nov 16, 2012 | 12:22 PM
sl55 amg
ya it is!
