SL55/63/65/R230 AMG: Heat Exchanger consensus
Anyways, for those running the secondary h/e which size did you end up going with? The 2" deep unit or the 3.5" unit?
I also noticed that the trend with the SL55's setup is that he stock and 2nd h/e are run in series with each other. Anyone have a diagram of this?
Thanks!
In addition, here's a shot of the belt wrap kit I just installed today:
there is lots of diagrams i found showing the direction of flow, but, you can also look at the pump flow direction, and figure it out by tracing the lines. it is a very simple system. it would almost make no difference which way the water traveled. just keep your pick up point low (you want to run through stock he first, then to the aftermarket he) i ran pump input line off of the aftermarket he and output to the intercooler.
This is from the FTP fb page:
"I have been driving the car for a couple days since install and can tell temps running lower than usual. Car seems to pull noticeably harder each time I get on it. Installation on the Sl55 required us to leave the stock heat exchanger and loop it to the intercooler pump and FTP H/E. We also had to set the oil cooler behind the FTP H/E. The bumper fitment was a bit difficult but not impossible and required some trimming on the inside. The customer ...service I received was from Steve has been top notch. I was concerned about what lines to run where for the plumbing but received a link to a diagram from Steve that made the job too easy. The FTP heat exchanger is a must for any stock or upgraded AMG"
anywho, raffi, the one i have is 3.5". i did post a link in my build thread to the exact one i purchased. same as frozenboost, but a little cheaper. i went abit crazy on the mounting anticipating a car that can reach 200mph and the wind pressure in that area though and modified the mounts.
you will need to change position of the oil cooler though. i was able to do it by just loosening the lines (but still connected) and twisting it up to be above the bumper bar. will need to cut the shrouds on the side though to accomadate this. keep the he flush with the bumper and you should be fine with fascia clearance.
Anyway, yes I am going to buy the newest pump which is the 010, and the heat exchanger I am going to purchase from frozenboost.com with the 3.5" core. Regarding the belt wrap kit, I haven't even driven it after it was installed haha. The car is still at the shop and almost done with the facelift conversion. Either way I think it's worth the money, lots of positive reviews on it. I think I even saw somewhere that it gained ~20hp with just the wrap kit. Can't go wrong.
Yup i am loving my SL each day by day. And the HP bug just bit me so. I am in the hunt for the HP gain mod. like secondary HE, belt warp kit, ECU tune. That will be it i guess. i don't want to go for bigger pulley, because i live in hot climate country and don't want to shut out my SC in hot day. By your recommendation i will pull the trigger on belt warp. who that's guy again? how did you process your payment and item?
It's very nice to see you with on going progresses. keep up posted tho. you just got one fan!
Cheer! =)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
http://shop.zzperformance.com/store/...Exchanger.aspx
any issues with the oil cooler?
