SL55/63/65/R230 AMG: Purchased 03 SL55 AMG with very LOW Oil in Crankcase
Old Feb 12, 2013 | 03:22 PM
LagunaBeach's Avatar
2003 SL55 AMG
I recently purchased an 03 SL55 AMG and yesterday I had the oil changed out. I was SHOCKED to find that only 4.2 Quarts of Very Dirty Oil came out of the crankcase. The oil level as all of you know is 9 Quarts.
My question is... What potential damage could have been done to the engine ?
YOUR REPLIES WILL BE MOST WELCOME.
Old Feb 12, 2013 | 07:52 PM
WHTEVO's Avatar
07' SL65, 04' E55, 03' Evo8, 08' GSXR, DSM's...
For starters i think i would change out the oil level sensor. You should have been getting warnings non-stop about a low oil level.
Being extremely low on oil can do quite a bit of damage, especially if driven hard. You are probably ok though. No weird noises or glittery oil right? Good luck.
Aaron
Old Feb 13, 2013 | 03:56 AM
2003 SL55 AMG
Thanks Aaron for your reply. The suggestion of changing the oil level sensor is exactly what I thought to do as well. The engine seems to run fine... no glittery oil..
Old Feb 13, 2013 | 09:38 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
fill it back up with 9 quarts. Buy a MB dipstick tool and monitor oil consumption.
Old Feb 13, 2013 | 09:53 PM
GermanCars's Avatar
2020 E450 Wagon
Hello, McFly.........there are two drain plugs!!!
Seriously, there really are two drain plugs on a SL55 oil pan. For goodness sake go back and drain BOTH sumps and refill it with 9.5 quarts. Don't drive the car overfilled with oil.
Old Feb 13, 2013 | 10:04 PM
2003 SL55 AMG
This is the fist time I have heard of this car having 2 drain plugs.. I went by the DYI video posted on here.
Are you sure there are 2 plugs in an 03 SL55 AMG ?
Old Feb 13, 2013 | 10:08 PM
GermanCars's Avatar
2020 E450 Wagon
Yep, at least my '04 does.
https://mbworld.org/forums/sl55-amg-...hange-diy.html
