SL55/63/65/R230 AMG: DIY : Command/Head unit/Navigation upgrade
2 things you need to be aware of when purchasing, 2003-2004 get the short wire set, 2005-2007 get the long wire set. they will message you to see if your car have optic fiber amplifier, well, we all do, but just tell them NO. I said yes and the result is $300 on labor just to hook up the thing with the correct wire and plugs.
before installation, you will need a couple of things:
1. a 5 channel Amplifier for the stock bose speakers and sub
2. a 4 gauge wire kit
3. 3 sets of signal cables ( amp to radio )
4. a 2 channel 3.5mm mini to RCA cable
5. a 1 male to 2 female Y adaptor cable
6. 4 bass blockers/by pass
I will be in SF this weekend if you don't mind I like to come by and check out your project. I am looking to upgrade my unit like yours.
now connect everything like this video
ps : and a night shot to conclude this DIY. Good night everybody!
1. Have you had any problems since installation? Does it seem reliable and well-built?
2. Where do you purchase the navigation data? Has yours been accurate?
3. I see that this unit is advertised as "plug-and-play." If I don't need to change amps, do you think this is a DIY project for a reasonably skilled recovering moterhead?
Motor on,
SJH
Motor on,
SJH
2. you dont have to purchase any navigation data, it came with a micro SD, it's been very accurate to be honest, it's more accurate than apple's map
3. it is NOT plug and play, you have to change the amp, if you have experience with car stereo this project is easy.
I was planning on putting the details in an original thread one day ....
but to answer your question briefly, here is a little more detail on my head unit
https://mbworld.org/forums/sl55-amg-...ml#post6444680
Cheers,
Chris
