SL55/63/65/R230 AMG: 2013 R231 SL63 with AMG Performance Suspension question...
JumpinJim (member here) explained its a 30% stiffer suspension set up (thanks again Jim) than that of the normal 2013 SL63 but I was wondering if anyone here has the exact definition of this option and what mechanical changes it entails (option code 486). I cant find it on the mbusa site because you can only build a 2014 now and its not an option.
Does anyone here know? Thanks in advance.
Maybe that's something that you can heavily negotiate into the price now that it's on a left-over 2013.
http://www.nacoutlet.com/specs-and-p...13-351394.html
SPECIAL ORDER OPTIONS
SPC
Special Order Option Charge
486
SPC
486
Thank you but I have this info (see my og post)... Im trying to find out what it really entails...
so I leave it standard . It holds the road better than the old SL even on
standard settings. The performance pack I was told was an increase in power
and a slightly lower ( 10mm ) ride height, there was no mention of stiffness.
on a side note: I drove 2 SL63's in a row for 30 minutes each on the same roads and highway. One had the Perf Suspension and one was the normal ABC AMG one. It was very clear how little body roll and how taut the perf suspension gives vs the normal one. The sharp turns yeilded a very neutral level experience with the Perf Suspension car. On higher speed roads where there were undulations the compression and rebound was much tighter and limited in travel vs the normal ABC. Now the comfort was not as good but on any normally paved, well maintained roads Id take the Perf Suspension over the normal ABC. (all my driving was with the shock light on or sport mode)
"I am looking at a new 2013 SL63 and it has a 1500 dollar special order add for "AMG Performance Suspension". The cars I have test driven all have the standard AMG ABC set up. I was wondering if anyone here has the exact definition of this option and what mechanical changes it entails (option code 486). I cant find it on the mbusa site because you can only build a 2014 now and its not an option.
thank you"
RESPONSE
"in a nutshell the 486 AMG Performance Suspension is stiffer with a more track/performance orientation to the software tune of the Adaptive/ABC aspects...there are also hard parts differences as the springs and shocks are different part numbers..."
__________________
William Vetter
Asst. Product Manager - AMG & Black Series
Exclusive Vehicles
Mercedes-Benz USA
thank you"
RESPONSE
__________________
William Vetter
Exclusive Vehicles
Mercedes-Benz USA
I love the ABC with the performance suspension special order. The neutrality of the car is amazing especially with it weighing in at 4k lbs and pushing it at 120mph in high speed bends.
Active Body Control also available as performance suspension
As an option, the AMG performance suspension is also available for the SL 63 AMG from the AMG Performance Studio. Damper characteristics can be made stiffer by up to 30 percent in both modes. This provides for even less body movement and is recommended when striving for high-speed laps on a closed-off racing circuit, for example. Another notable feature of Active Body Control is the variable roll moment distribution between the front and rear axles, which the system carries out automatically according to the driving situation and speed. The computer uses various acceleration sensors to obtain information on the current driving situation and compares this data with those from the pressure sensors in the spring struts and the level sensors on the control arms. The system then computes the control signals that the servo-hydraulic valves at the front and rear axle transform into precisely metered flows of oil. In addition, the SL 63 AMG is fitted with hydraulic all-round self-leveling which helps to ensure a constant vehicle level irrespective of the load being carried.
