SL55/63/65/R230 AMG: Suggested MODS for 03 SL55
Old Nov 23, 2013 | 05:10 PM
DangeRuss's Avatar
2003 SL55
As Tim the tool man Taylor would say my SL55 needs MORE POWER!!!!!!
I will be ordering a Pulley kit and a tuned ECU this up coming week, anyone have more suggestions for me to get some power to the pavement
Cold air kits?? Good or over priced bunk??
http://www.ebay.com/itm/Mercedes-Benz-AMG-Performance-Cold-Air-intake-System-CL55-E55-SL55-S55-CLS55-ETC-/151164965087?pt=Motors_Car_Truck_Parts_Accessories&hash=item23322250df&vxp=mtr
Any and all suggestions are welcome, Thanks
Old Nov 23, 2013 | 07:40 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Headers, tune, 82 mm throttle body, larger crank pulley or smaller supercharger pulley, and belt wrap kit. If you really want some big power, go for an upgraded supercharger. Lots of good vendors on the board. Do a search.
If power is what you are really after, trade the 55 in for a SL600 or 65 and do some turbo, tune, and exhaust work. You can have 1000 hp for not a whole lot of money in the grand scheme of things.
Old Nov 23, 2013 | 09:14 PM
kustom2k1's Avatar
03SL55
Our cars come with cold air kit from the factory.
Old Nov 23, 2013 | 09:47 PM
BenzoBoi's Avatar
Super Moderator
W221
Front mount heat exchanger, headers, throttle body, LSD, better tires...to start.
Old Nov 24, 2013 | 08:32 AM
ttboost's Avatar
CTS-V
Was gonna suggest the same thing...
Old Nov 24, 2013 | 08:56 PM
cnterline's Avatar
2003 SL55,2020 GTC ,2017 GTS sold ,2002 G500 Sold,2003 SL500 Sold,
I have an 03, Kleemann 168 bottom pulley with tune, smaller upper pulley,Kleemann cams,MB 82 mm throttle body,Kleemann headers,Quaife diff,trunk tank,extra front heat exchanger,PTE thermostat,Dashdaq XL ,dual Zeitronics wide band sensors,pilot super sports all around,Kleemann TCU tune ,
Old Nov 28, 2013 | 04:13 AM
SL55K's Avatar
AMG
Go for a Weistec SC.
I had the Kleemann K4 for 6 years, weistec destroys everything about kleemann
Old Nov 28, 2013 | 04:14 PM
BlownV8's Avatar
I haven't read any real positive comments on the Weistec 55k cars. All I'm reading on the forums is how you need to run a trunk mounted water tank and methanol injection because the IAT's are way too high. When you are forced to run methanol, it means that your intercooler is too small for the task. Judging by the pictures, it looks way too small.
Tell us about your experience. It would be good to hear something positive.
Old Dec 1, 2013 | 03:11 AM
SL55K's Avatar
AMG
Ive been using the Weistec SC for over a year now
My car is a full Weistec build car with the Kleemann parts still intact. Had them do some custom work since I was looking for more power than the standard Weistec conversion.
I have no issues whatsoever with the cooling of the car, yes I did change the intercooler a while back since my stock intercooler went bust after so many years (its an '04), changed it to the SL65 intercooler which is sold by SpeedDriven, no issues at all, car is always at a stable 75C in the winter and 95C during the summer.
I live in the Gulf so it gets pretty hot here, still no issues with the SC nor the cooling.
I did however have to go with the Weistec TCU instead of the Kleemann TCU i had, the gear would slip on the third gear at full throttle with my old setup.
Cars been running perfectly ever since, i use 103 octane though while driving, huge bump in performance feel from the standard 91 octane they did for me.
The moment you floor it, you forget everything about Kleemann and have the biggest smile on your face.
Only issue I am going through are the struts, I keep on changing them and its becoming worse and worse, either i will go for a coilover conversion if i can find any vendor who can help me, or i'll just ask www.strutmasters.com to send me their struts made for the SL55
Old Dec 1, 2013 | 02:41 PM
BlownV8's Avatar
OK, I'm a bit confused. What Kleeman parts do you have and what Weistec parts? You said you replaced the intercooler but didn't the Weistec unit come with an intercooler or do you mean you replaced the heat exchanger in the front of the car? Are you running Methanol and a trunk mounted water tank?
Old Dec 1, 2013 | 03:28 PM
DCMETRO22Z's Avatar
E320
Without answering for SL55K, I have read his build thread so Yeah he changed the Heat exchanger for a Speeddriven unit.
Weistec SC comes with it's own integrated intercooler.
He has Kleemann Headers & Cams for sure because I asked the same question, I wanted to know i those worked with the Weistec unit he said yes.
SL55K Am I right ?
Old Dec 7, 2013 | 01:53 AM
SL55K's Avatar
AMG
SL55K Am I right ?
My bad guys, I meant to say the H/E kit and not the intercooler.
As to answer your question regarding the methanol and ice tank by weistec, i dont use them.
as for you DCMETRO22Z, yup youre right, headers and cams only from the Kleemann package
Old Dec 7, 2013 | 11:05 AM
cal1's Avatar
SL55, ML500 & Acura TL
Just curious, what kind of power are you putting down? Also, any 1/4 mile data?
