SL55/63/65/R230 AMG: Thinking about getting a SL65 AMG
Old Jan 30, 2014 | 11:27 AM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Originally Posted by V12TTenthusiast
I mentioned that in the post but I think quad is right lol. If you do new turbos you need to build custom headers/manifold. No one sells M275 headers as the turbo is built into the manifold
The only turbos that don't require doing so are the rebuilt OEM turbo's will billet parts and larger wheel for spool up
Rebuilding the turbos is the only thing I've seen. Let me know if there is someone out there building the custom exhaust manifolds for the bi - turbo v12.
Old Jan 30, 2014 | 11:51 AM
cnterline's Avatar
2003 SL55,2020 GTC ,2017 GTS sold ,2002 G500 Sold,2003 SL500 Sold,
You can get sl55 into tens or close to it for a lot less
Old Jan 30, 2014 | 01:53 PM
dllhg's Avatar
2014 cls63 a amg. 2018 AMG GTR
No headers on a SL65. I don't know of anyone who makes them. There is just no room. The turbos are integrated into the exhaust manifolds. It is very tight.
Sorry I missed the part about those turbos requiring new custom headers. Speeddriven even said it was bolt on other than you need trans work..... If they are not including the headers then they are way off base. A turbo "kit" should include headers and anything else needed to install it. That being said headers arent nearly as important on a turbo car anyway. An electronic cutout right at the downpipes would increase the power a good 40-50 WHP and spool the turbos much faster. I used to have a boost activated one on previous car and it would be totally quite for all normal driving. Once hit it 5 PSI it would start to open and I think 10 PSI it full opened. No switches to mess with. Made a HUGE difference. Turbos just hate exhaust restrictions.
all I can say is good luck with an under $40k Sl65.
you seem to not want to heed people's advice, so go forth and good luck.
I dont set the prices Fact is they can be had for under 40K if you look around just a little bit. I just did a two minute search and came up with 5 of them. one has only 45K miles on it to boot.
What advice is it you think I am not heeding ? I guess you think people just shouldnt go out and buy a SL65 I already said I would get a warranty. I also decided to ditch upgrading the turbos since other members are getting in the 660 WHP range with bolt ons.
Maybe some of you aren't really reading all my posts ?
Old Jan 30, 2014 | 06:59 PM
carlsturm's Avatar
Everyone should own an SL65 once in their life. Nothing compares to the nonchalant, casual, unassuming way a V12TT achieves speed. It just goes fast in it's sleep.
I'd recommend you take some time to find an SL65 that is covered under CPO. It's major peace of mind knowing your Benz dealer will take care of you when you have an ABC failure, ignition coil failure, transmission failure, whatever.
ABC suspension may have it's issues but IMHO it's superior for everyday driving. I don't track my SL and love the way ABC keeps the car flat and composed in the curves, when braking & when accelerating. The SL65 never feels like it's sweating or stressing.
Old Jan 30, 2014 | 08:22 PM
ttboost's Avatar
CTS-V
This definitely is not a cost effective car to build, but it's really not a car to be building. Flash it, runs 10's and just drive it around with the top down. I've owned mine since last August. Already needed 2 coils and a IC pump. Found the coils for a tick under $800 each and the Bosch 010 pump is $100 on Amazon. About an hour and half for each job at home on the lift. Did a Eurocharged ECU/TCU immediately after I bought it. Went to the track and went 10.99, almost 128 2nd pass. I think there's more in it as is. I don't plan on doing a lot more to it...maybe sticking my meth kit on, maybe some catless DP's...not sure I want it that loud though...already have no mufflers.
Just buy the nicest, newest one you can afford, hopefully it already has a bunch of new stuff. Good luck with your search..you won't be disappointed..
Old Jan 30, 2014 | 08:54 PM
Wolfman's Avatar
Super Moderator
Originally Posted by dllhg
I just read a thread stating they were quoted $700 parts and labor for all three mounts. I had all my mounts done with my header install on the E55. Only had to pay for the extra parts. So not too bad.
Is it hard/expensive to do the ABC flush and fluid ? Seems like a pretty easy thing to take car of unless you need to do it every oil change.
nothing scaring me away from this car yet. Unless I hear the trans or engines are weak I am in like Flynn
Really seems about the same price wise as my E55.
Engine mounts on a SL600 or SL65 are the same costs. This will cost you minimum $2.5k - $3k. Parts are nothing. It is all labor since the engine has to come out of the car due to its size.
On the good side, if you take the engine out you can easily get work done on the turbos
Old Jan 31, 2014 | 02:21 AM
  #32
dllhg's Avatar
Appreciate all the input. Needless to say I am sold on one of these. Tune only run 10s I thought about a SL55 AMG since they can be had for mid 20s all over the place. What I dont like about that is it is the same exact motor/blower I already have. Takes LOTS of parts, lots of fine tuning to get it in the high 10s. Probably even more since it weighs more than the E55. Just as good looking as the 65 and has the convertible factor. TT V12 is worth the extra price of admission.
As far as the mounts go I read a few threads saying you dont have to remove the engine which is why the price varies so much.
Old Jan 31, 2014 | 07:30 AM
  #33
ttboost's Avatar
CTS-V
If you can wrench on it yourself, you will safe boatloads...labor is usually more than the parts, depending on the issue. I read all the horror stories and bought one anyway. Sure I has some failures within a month of buying it, but after reading this forum, I expected that and was ready. Found coils at RockAuto and it only takes about an hour and a half to change both. The only issue I would have is the ABC. If mine fails, I might consider aftermarket if it is available now...I hear it is...
Old Jan 31, 2014 | 10:36 AM
  #34
pjdough's Avatar
1999 E55, 2005 SL65
dllhg - the decision is binary. Do you have the $ to purchase [a reliable] 65 and maintain it (be sure to check service records and previous owners, if you can find em)? If not - go with a 55 or 63 (certainly no slouches, mind you).
If the $ is and will be there, does settling into and driving a V12TT truly put you in a special place above and beyond a V8TT or SC...so much so that the $ invested doesn't matter [that much]? Dont get me wrong, there are other places I'd rather be...some of the time. However, when I fire my 65 up and drive her like no other vehicle I've had (and I've had many), there's a zen-like quality to it.
SL65s are truly a luxury sports car that require detailed attention - not unlike high performance boats, aircraft...and women. If you don't treat em right, they'll break you.
Good luck in your search and keep the shiney side up!
P
Old Jan 31, 2014 | 01:42 PM
  #35
Speedriven1's Avatar
Speedriven
If you have reliable and knowledgeable Mercedes independent shop, they are really not that bad.
Old Jan 31, 2014 | 01:58 PM
  #36
dllhg's Avatar
P
You make some very points. I could get a SL55 and mod it up to be almost as fast as a tuned SL65 but I wouldnt be saving much. On my E55 I think I was at about 7500 parts labor and that was after really shopping around with good deals. Those SL55s can be had for 20-25K pretty easily now vs flat 40K for the SL65 I would save maybe $13K and have the looks and convertible etc I am wanting. I would have a car though that is a tick slower than my E55 which kind of bothers me. Not to mention I have always wanted a twin turbo V12 AMG. I could also just get pulley/tune water chiller and call it a day and be at least 15K under. I am sure it would be fast enough. The 55 and 65 look identical to me and I can only tell when I see the badges. Sexy cars for sure.
Doesnt the SL55 share the same ABC system ? I'll give it some time
. I am currently trying to wrap our new home purchase so it will be 5-6 months before either becomes a reality. I won't be doing any kind of financing. The 55 would be a lot easier to convince my wife of on a third vehicle but she is always really cool about my car purchases. Especially since I got her the Turbo Cayenne
Old Jan 31, 2014 | 06:47 PM
  #37
richvegas's Avatar
2016 S65 AMG coupe, 2010 E63, 2015 Z06/z07 m7 vert 735rwhp, 2000 f-350 crewcab w/ 16" kelderman kit
coming from someone who's done them... in a S or CL car you do not need to take the motor out of the car. An SL65 r230 chassis it is impossible to remove the mounts with the assembly in the car. Any threads talking about keeping the motor in are on S's or CL's.
Best of luck!! i love my S65 and will soon own an SL65 when i find the right one.
Old Feb 1, 2014 | 09:50 AM
  #38
Benz-O-Rama's Avatar
Concur.
SL600 and SL65, the engine must come out to do the mounts. As a matter of fact, if you look at the procedure it says:
Step 1. Remove engine.
Not making that up.
Old Feb 1, 2014 | 09:58 AM
  #39
ttboost's Avatar
CTS-V
Not that I am a nonbeliever, especially if you have done it. My RS6 was supposed to be the same way, but you always find a way. I'm curious to see how bad it is next time I get it on the lift. I would think with downpipes off, you had a route out...
Old Feb 1, 2014 | 11:36 AM
  #40
pjdough's Avatar
1999 E55, 2005 SL65
"That bad" is subjective, if you're talking about maintenance incl parts and labor. For example, a full brake job at a bargain rate of $3000 - 3500 may be a bit high for some. Or, replacing 24 spark plugs for ~$300 sans labor may seem unreasonable to some. Just saying, let's not kid ourselves... 65s likely aren't considered "not that bad" by most. If your unsure if you can afford, even with the best of indies, you probably can't.
Sent from my iPad using IB AutoGroup
Old Feb 1, 2014 | 11:54 AM
  #41
dllhg's Avatar
The mounts will go out too .... bummer. Mine were replaced on my E when I had all the work done. They were shot with only 60K of stock driven miles on them.
The Sl55 or maybe even the CL65 are looking more attractive .... That or just make sure I have a good warranty I suppose. I really want that power train and I really like the body style of the SL. I thought about the CL65 since you can get those for mid 20s and have the same awesome power train. They dont really look any better than my E55 though. Maybe they do in person. At least it has a rear seat and a real trunk. Would probably end up driving a car like that 50% of the time where as the SL it would be 10%. The SLs just really get me going whenever I see one.
Why are the SL65s so much more than the CL65s?? Both were about the same MSRP but SL is $40K and CL is $25K
Old Feb 1, 2014 | 01:22 PM
  #42
Wolfman's Avatar
Super Moderator
Sl65 are simply more desirable cars than a CL. You get a coupe and a convertible in one car plus it ages much more gracefully. Loved the CL when we had one though. Interior is beautiful.
That said I recommend getting a SL65. Don't bother with an SL55 or a CL.
I personally feel that the repair cost discussion is overblown. Consider it the cost of ownership of owning a former $200k+ car at a mere fraction of that.
Simply add $5-7k to you annual budget and enjoy! It will not diminish the experience...
Old Feb 1, 2014 | 01:38 PM
  #43
V12TTenthusiast's Avatar
06 SL65AMG, 13 Tesla Model S 60kwh, 02 Jaguar S-Type 3.0, 12 S550 4 Matic, 07 E320 Bluetec, 06 LX470
If you want a 4 Seater with a a nice 65 engine then get a CL65, if you want a nice hardtop roadster then get the SL65. If your worried about maintenance just get a warranty and just make sure you have that 3.5-4.5k when the brakes need to be replaced.
For performance mods if you just want to do 10s just get a Heat Exchanger, IC Pump and an ECU/TCU and call it a day and you can do mid to high 10s np
Anything else will start costing money but considering where you get your ECU/TCU tune, your HE and pump its prob only 1500-3000 more for a constant 10s car.
But for 25k the CL is very attractive, I'm been thinking about buying an 05-06 CL65 on top of trying to purchase a 07-08 S65
Old Feb 1, 2014 | 07:04 PM
  #44
We had the full exhaust system dropped. Engine must come out.
Old Feb 2, 2014 | 12:13 AM
  #45
dllhg's Avatar
Hard for me to ignore the $15K price difference for virtually the same performance. Probably another 2K more for motor mounts over the CL as well. Does the SL65 handle better? You would think it does. I love the idea of having a convertible. I drive on a lot of roads in the redwoods and on the coast it would be amazing. Problem is I usually end up having my 6 year old son in the car 5 days a week and a two seater isnt really great for that. It would need to be my weekend car only where as the CL I could drive anytime. Couple hundred pounds heavier and doesnt look nearly as cool as the 65 plus no convertible make it really hard to decide.
Old Feb 2, 2014 | 02:06 AM
  #46
Wolfman's Avatar
Super Moderator
CL sell for less because less people are interested to buy them
Old Feb 2, 2014 | 02:29 PM
  #47
BlownV8's Avatar
They are not nearly as attractive as the SL but the 4 seats do come in handy.
Old Feb 5, 2014 | 01:16 PM
  #48
ttboost's Avatar
CTS-V
Thanks. How long to get engine out, with lift and a table such as yours?
Old Feb 12, 2014 | 05:46 PM
  #49
MayhemLikeMe's Avatar
SL65
Have I got a deal for you.....
https://mbworld.org/forums/sl55-amg-...move-65-a.html
