SL55/63/65/R230 AMG: Removing the resonators from an SL63?
I have removed the resonators from the previous three SL55's that I had and it made them sound great. It increased the volume slightly without changing the tone of the exhaust or becoming obnoxiously loud with drone.
Has anyone removed the resonators from their 09-11 SL63? I have read various results on the C63 forum but their exhaust layout is slightly different. It seems that their resonator is one piece where both pipes merge and ours has two separate resonators instead.
Maverick: Quite the stable you got there. Did you take out the resonators on any of your M156 cars?
I can tell you it makes it sound like an exotic car and it is much much much louder. When I drive with the cutouts open and it flows freely the openings it very loud even at low speeds. And at WOT ive had people tell me they could easily hear me 1-2 miles away, but when your cruising in your car at 40 mph you can hear it clearly and it can be a good and a bad thing. If you have cops behind you or you have a bad thing it can be a bad thing.
With no cats, cutouts closed and having the exhaust flowing to the hi-flow mufflers its loud only at WOT but when your cruising its quieter so if you have a headache or if cops are following, it will sound a bit deeper but wont give you that "hey look at me" sound.
Investing in cutouts was a well spent extra having the ability to open and close that cutout valve
I'm assuming you had the mid-mounted resonators cutout and not the rear mufflers as seen in this picture, correct? What year is your SL and is there any way I could talk you into recording a couple of quick sound/video clips with your phone?
sounds spectacular with your foot down. I never fiddle with exhausts I like
quiet cars, except when your gunning it.
Overall amazing mod and best $100 ive spent. I kept the resonators so if i ever get bored, i can always get them put back on lol
https://www.youtube.com/watch?v=rTaPDLNyTDs
These are the resonators (part 159 in diagram). Have them remove the resonators and replace with straight pipe. Also have them remove the secondary cats (part 158 / B in diagram) and put an x-pipe in their place, this will not cause any CEL or issues as they're post O2 sensors. It will smooth out the sound and help with exhaust scavenging since it's an NA engine. That price sounds reasonable if they're doing all of the above mentioned work.
