SL55/63/65/R230 AMG: SL55 transmission blocked in 2nd gear
Old May 29, 2014 | 03:27 AM
Z_de_Suisse's Avatar
W211 E63 AMG / W124 E500 / Lancia Delta Integrale Evo2 / Lotus Elise 111s MK1
Hi Everybody,
I'm a new comer from France that just received his 2002 SL55. I bought the car with an ABC problem, but what I did not expect was that the gearbox would be a problem as well.
I do not have any error message on the screen, but the car is in W mode. The stick moves without any problem in P, R, N and D, but once the car is on the move, the gearbox does not change the selection and stays in 2nd gear. I can drive up to 6'000 rpm and approx 100 km/h and nothing else will happen. Same with manual selection, nothing happens.
The car has been staying several month on a parking without moving. The engine batterie was weak but could start the engine but the second batterie in the trunk was dead and I had to replace it by a new one. I was wondering if this could have triggered a "security" mode or something electronic that would impact the transmission ?
Any clues or hints welcome.
Old May 29, 2014 | 05:46 AM
And some pics
Nice car !
Front right suspensions ... the other do not look much better
Old May 30, 2014 | 07:33 PM
149 views and 0 answers ... somehing wrong with my question or nobody has a clue ?
Old May 30, 2014 | 07:45 PM
nsxguy's Avatar
a few cars, few bikes,04 SL55
I had a similar problem I changed the transmission conductor plate and back on the road again.....
I am not sure if this would solve your problem, I am just sharing some info of what I did..
http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
good luck !!!!
Old May 30, 2014 | 11:46 PM
benz_addict's Avatar
V12TT
Nice car. Looks like the transmission is stuck in limp mode. Get the codes read. Clean the TCU could be full of oil. Take this as replacing the transmission fluid, adapter plug(important), gasket. Problem could be the conductor plate as said above make sure everything is nice and clean when putting back. Could also just be low fluid but I would just service the transmission fully. ABC shock looks bad, must be replaced. Good luck.
Old Jun 1, 2014 | 03:36 PM
Thanks for the tips. I will start there and keep you posted on the progress.
Old Jun 1, 2014 | 03:49 PM
Great video on the problem by the way
Old Jun 15, 2014 | 05:10 AM
I did follow the instructions from the video. Very easy to do and after a visit to the Mercedes workshop to erase the codes everything works fine now !
Thanks for the hints, it helped solving my problem.
I still need to solve the problem with ABC, but as posted in another thread, I have found a solution.
