SL55/63/65/R230 AMG: SL55 Bi-Xenon, these cars dont have Bi-Xenon?
These cars DO not have Bi-Xenons, am I correct? for what I know Bi-Xenons uses the same HID bulb for the high beams, or it has the auto leveling. The SL55 does not autolevel upon start up, also, uses halogen bulb for high beams?
Does anyone know why MBz says this car have the Bi-Xenon headlamps when its really a fixed HID projector headlamps?
The halogen hi beams are still used on bi xenon cars. This is important for the flash to pass function as HIDs require warmup, the halogens turn right on.
The BiXenon function uses a shutter inside the projector. If you flip the hi beams on/off with headlamps on and engine off, you can faintly hear the shutters click.
Leveling is done via ABC. Headlamps are aligned at installation. with ABC maintaining vehicle height/level/trim at each corner even when loaded the headlamps also are effectively always level
So the halogens are also still used for high beams, as well as the xenons themselves, the shutters opening to allow more light out the HIDs, thus when hi beams are on, both the HIDs and halogens are being used?
Im a little confused...i guess I'm used to the new Bi-Xenon MBz has on their latest models..
You can convert the highs and fogs to HID xenon with kits and most have learned to add a in line capacitor with their kits to make them instant on, so they do work as normal bulbs for blink on highs
