SL55/63/65/R230 AMG: brake bed in procedure?
Old Jul 9, 2014 | 01:29 PM
SS2Z06's Avatar
2006 SL55
I just replaced my front pads and rotors and I hear there is a bed in procedure. Can someone please tell me what that is. I have a low speed pulsation that I can't trace down. I checked the run out on all 4 corners and is good. The pulsation didn't start until after the brakes and am hoping this may help. I am at a loss otherwhise. Thanks for any help or advice!!!
Old Jul 9, 2014 | 03:47 PM
kittyandgary's Avatar
2003 SL55 AMG
If the pads are ceramic (i.e. EBC Red Stuff, Akebono, etc.), these manufacturers usually recommend NO hard braking, only normal suburban driving for the first 500 miles. After that, and occasional hard braking from 70+ mph is probably good for the pads and rotors.
IF they are the semi-metallic pads, these generally recommend about 3-4 hard slow downs from 60+ to ~20 mph in sequence, followed by an extended drive to cool the pads/rotors without much braking. These pads need some heat to 'bake' the matrix in the pads.
Old Jul 9, 2014 | 03:51 PM
SS2Z06's Avatar
2006 SL55
They are factory pads so Im not sure what material that is. I just don't get why the pulsation now.
Old Jul 9, 2014 | 04:48 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Sounds like they still need to bed in but I think factory pads also require easy stops for first 500 miles.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Jul 9, 2014 | 04:58 PM
SS2Z06's Avatar
2006 SL55
I'll continue to drive it and take it easy. Ive done MANY brake jobs and never heard of having this happen and it going away after a proper break in but I don't have any other ideas.
Old Jul 9, 2014 | 05:40 PM
screw991le's Avatar
2010 E63 AMG
Thanks, I am getting new front rotors and pads next week. Mine are warped and they are replacing them under warranty. Totally stock
Old Jul 10, 2014 | 01:18 PM
pdjv's Avatar
2011 E550, 2008 SL55 AMG
Do the brakes pulsate under all conditions (hard brake, moderate brake, light brake)?
Check the surface of the rotors for pad material that has accumulated on the rotor. Then, if there's a stretch of road where you can do this safely, get the car up to 60 hard brake down to 5-10 mph - repeat for a total of five times then let the brakes cool - gentle stops. If this doesn't clear up the pulsation you probably have one or more rotors with just enough runout to case pulsation.
