SL55/63/65/R230 AMG: help with tuning
Old Aug 5, 2014 | 03:36 PM
R66NED's Avatar
Sl55 AMG
help with tuning
hi guys
im looking at a few smaller pulleys for the charger what size would you recommend ? and are these clutchless ones ok to use ? and depend what pulley and after a remap what sort of gains should i expect, im also uprating the IC pump as mine is starting to fail
cheers
Old Aug 5, 2014 | 04:01 PM
kingnash's Avatar
03 SL55
get the smaller 84mm pulley from shardul and remap with eurocharged tune. Should expect 40-50whp.
get the bosch 10 ic pump. no splitting wires/ just plug and play. Works as good if not better then johnson pump, and johnson you need to split wires.
if you want additional mods, i suggest focus on cooling upgrades (secondary heat exchanger) and split cooling
Where are you located?
Old Aug 5, 2014 | 04:10 PM
R66NED's Avatar
Sl55 AMG
lovely cheers mate, very helpfull answers and was looking at a 77mm pulley will that be too much then and located in south east london UK
Old Aug 5, 2014 | 05:41 PM
JohnH's Avatar
2004 SL55 AMG
Have had pulley, EC remap, modified exhaust, new IC pump, secondary heat exchanger and LSD. Make it a totally different car. Not had chance to run on rolling road but certainly performance is in a different league to standard. Can be done by Eurocharged UK based in Watford 0203 2907049 or sales@eurocharged.uk.com.
Old Aug 6, 2014 | 03:38 AM
R66NED's Avatar
Sl55 AMG
Thanks mate, il give them a email or ring and get some prices, what exhaust mods did you have done
Old Aug 6, 2014 | 05:13 AM
fxrs1955's Avatar
2014 SL550
You might want to upgrade your heat exchanger as well as your pump. These cars make a lot of heat.
Old Aug 6, 2014 | 07:04 AM
JohnH's Avatar
2004 SL55 AMG
Had the secondary cats and resonators removed. Does sound a lot better.
Old Aug 6, 2014 | 03:43 PM
R66NED's Avatar
Sl55 AMG
Yeah I've read about the heat exchangers, are they easy to get hold of and do you have to do much plumbing in or dose it just replace the original one and yeah exhaust wise I was goin to try and get a custom one with valves in so I can loose the drone on a long journey
Old Aug 6, 2014 | 04:25 PM
JohnH's Avatar
2004 SL55 AMG
The Heat Exchanger is fitted as an addition to the original one. The original is located behind the radiator. The additional HE is fitted just below the radiator. The first one sent by Eurocharged did not fit but the second one did. Had it fitted by PCS near Portsmouth but Eurocharged in Watford could fit. Pictures below.
Before HE Fitted
After HE Fitted
Old Aug 7, 2014 | 10:20 PM
IngenereAMG's Avatar
SL55AMG, Ferrari 348, Ferrari Testarossa, Ferrari F40, Ferrari Mondial t, Ducati 916, Indycar
hi guys
cheers
Hi:
We've been developing and tuning these cars since the beginning. You will love our work ad well as the performance and reliability. Here's links to our MB page and testimonials.
Let me know if you have any questions.
http://www.veloceperformance.com/mercedes.htm
http://www.veloceperformance.com/testimonial.htm
Old Aug 8, 2014 | 02:34 AM
JohnH's Avatar
2004 SL55 AMG
Think open was looking for someone based in UK.
Old Aug 8, 2014 | 12:00 PM
cal1's Avatar
SL55, ML500 & Acura TL
hi guys
cheers
If you are only looking for a bit more boost and a tune and some cooling, I would agree wholeheartedly with kingnash's suggestions, however, you might want to think about what your ultimate goals are. I say this because if you ultimately get bit by the mod bug like many of us and continue to add mods, there is a better path IMO.
My very first round of mods included, larger counter pulley as smaller sc pulley's were not really available back then, Bosch pump, heat exchanger, and tune. It was the perfect mod to start with and end with. Unfortunately, I did not end there. If you are ultimately going to find yourself wanting headers, then long tubes and a tune is your best first mod in my opinion.
Regarding clutchless pulleys, you might want to pop over to the W211 AMG boards and do some reading. Here is a good thread that I have been following.
https://mbworld.org/forums/w211-amg/...leys-same.html
We are seeing more and more SL guys wanting to do mods, but the W211 AMG guys are still the mod kings IMO and we share the same motor.
Old Aug 10, 2014 | 07:55 AM
R66NED's Avatar
Sl55 AMG
Thanks guys really apprechaite the help, been very help full, defo the best forum I've been on so far
