SL55/63/65/R230 AMG: Ride height limiting on the Programa lowering module V2 (ELM)
Unfortunately the automatic height adjusting feature via speed is is still disabled or not working in the latest version. I had ordered ELM kits for two SL55's, installed them, uninstalled them, and then put lowering links on both cars. That feature was the main selling point (at least for me) when compared to the links.
. on a w211, it may be different (rear , left front, right front?)
2014 CLS 63 S AMG / 2004 E55 AMG
Thanks. I plan to use it on W221, a 2012 S63. I lowered the car on links, but the car doesn’t sit as level as I’d like across the 4 corners. Was hoping that this would help address it.
Do you have to keep it connected to the obd port, or do you disconnect it after you set things up?
