SL55/63/65/R230 AMG: Has anyone upgraded their head units to the Android Chinese Models?
https://www.seicane.com/android-gps-...usb-sd-s018817
http://hualingan.en.made-in-china.co...its-W-GPS.html
Before there was an android version out for an R230, I installed a competitor's android radio (made for a c class that I adapted into my SL55) https://mbworld.org/forums/sl55-amg-...ml#post6444680
When Hualingan finally came out with the android version (a couple of years ago?) I bought one (same unit as you linked, but for quite a bit less since I bought it direct). However, with so many other projects going on, I have not installed it yet.
Wish I could give you some feedback on the actual unit, but they are all 95% good with occasional glitches. If you indicated your model year, I could give you some more specific install info.
hope that helps,
Cheers,
Chris
I replaced my COMAND head unit with Pioneer AVIC 8200 NEX. Kept the Bose amp and speakers. Added a backup camera.
While there are "MOST" fiber interfaces available for your car, D2b cars (like the OPs) have none, so the AMP (bose) needs to be replaced or bypassed.
While I have not heard of many (any) of the chinese radios "failing", I will confirm that the build quality is mediocre and some of the features /hardware (built in mic for hands-free as an example) only meet minimum requirements. .... But, I have pioneer AVIC in my F250 that is a big disappointment , so, clearly, nothing is perfect.
I think that if you are a true audiophile, you would want to go the extra mile of getting a namebrand unit (like your pioneer) and then buy all of the add-ons to get the steering controls to work (and put up with the patched-in square-peg-in-a-round-hole look). In the OPs case, he will have to replace the AMP no matter what path he chooses (he can keep the speakers although it will be hard to use the factory BOSE sub with most aftermarket amps). Addtionally, the OP will likely have to cut his center console trim (and change out for later model cup holders) if he wants to put in an aftermarket unit while utilizing the standard aftermarket headunit bezel).
There is no perfect path, I always like to see the various solutions that members come up with.
Cheers,
Chris
I have r230 2003 with the D2b can I get this android radio will it work plug and play even without the amp , there is a bypass cable and most box
I have a 2003 r230 with the D2b , I want to get the android 7.1 will it work plug and play , There is a bypass cable will that do the trick?
Cheers,
Chris
If you can get the supplier to send you a PIC of the R230 bypass cable, post it here and I will tell you my thoughts on how plug and play it may be.
Chris
https://static.seicane.com/media/wys...S018817_25.jpg
Chris
Here is a thread where someone hoped to use the amplifier from a later SL so that he could keep the existing speakers with no modifications. Can not tell if he got it working, however.
worth mentioning, the is a Haulingan product (they are the manufacturer), if you can find it directly from them it should be $100 or more less expencive.
Cheers,
Chris
Cheers,
Chris
wish me luck if it ships that is
I took a picture of the R230 bose amp, so you can see what the "bypass cable" NEEDS to look like at one end.
by the way. sounds like you got a GREAT price .... nice job.
Cheers,
Chris
bose amp out of my 2003 sl55
https://www.aliexpress.com/item/Ouch...311.0.0.PdbPLq
together with Pioneer GM-D1004 as you can’t use the std Bose amp.
The headunit amplifier is driving the rear speakers and the dash speaker, the Pioneer amplifier is for the door speakers and the subwoofer which is bribged to two Chanels.
I made the installation over a weekend and is stright foreward but you need to route speaker cables from the dash to the rear as all speaker input has to be connected to the Bose amp connector behind driver seat. The extention cable that is recomended is not doing the job stright off as it has no connnection to the speaker wirwing, you need to buy a ISO speaker socket to connect the speaker wires as the one on the kit does not match.
The sound is as good as the original system, the steering wheel buttons, volume and channel change works but when you shift menue the station changes, I haven’t tried to change the settings on the buss device that was set to SL R230.
In total it’s a great upgrade to a fantastic car that now is a fully modern Super car.
will attempt to insall tomorrow or over the weekend
bought here can from seicane
https://www.aliexpress.com/item/Seic...311.0.0.XjA6u9
with the long cable
The built in amplifier is not powerfull enough to justufy the Bose speakers, I can asure you that you will regret not installing a amplifier. It’s minimal extra job as you already have to connect everything where the amp. Is located and the amp is arround $125.00.
I made the installation over a weekend and is stright foreward but you need to route speaker cables from the dash to the rear as all speaker input has to be connected to the Bose amp connector behond driver seat. The extention cable that is recomended is not doing the job stright off as it has no connnection to the speaker wirwing, you need to buy a ISO speaker socket to connect the speaker wires as the one on the kit does not match.
And I have no pictures. But the job is easy if you have replaced or installed car stereo before. I will try to give you som more info tomorrow when I’ve checked my file with documents.
In the backend I fitted ISO cables that correspond to the Amplifier as I did not use RCA cables to reduce the no.s of cables back of the Headunit.
Then I connected everything to the car amp cable socket using ISO flat connectors. The channels I used from the Headunit I added in parallel at the ISO socket.
I used two sets of each ISO male and female connectors with preassembled leads.
The picture shows what I cut away and in the same time is left.
I have kept all the original wiring intact so the car can be brought back to original in the future.
connector or did you use the short cable one)
I assume end marked 1 and 2 are the front since connector 1 is the same as canbus and connector 2 fits into new head unit.
Remember with Android units you have questionable quality, need an after market amp, and your time (maybe some special tools if for pulling trim if you don't have it). So you'll probably at a minimum have $600 to $750 into it and a weekend or so of your time.
For $1200 to $1500 you might have name brand quality unit with a warranty that looks just as good and probably sounds much better overall. They maybe able to use your Bose amp and if not they'll know right amp to pair with your system to get the most out of it.
Cut away remains
