SL55/63/65/R230 AMG: Ride height limiting on the Programa lowering module V2 (ELM)
Old 10-18-2014, 01:40 PM
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
Looking at the Programa unit since it's on sale for $599.
http://programainc.com/mercedes-benz...22210099r.html
It comes with the remote; for those of you who have this on your SL AMG, does this unit allow you to go back to "factory settings" above a certain mph? For example, I really only want this thing for looks, and I only see these "looks" when I'm actually not driving it and it's parked. The little things that annoy us right? .
So above 5 mph, I want this thing to go back to the factory height settings and do it's regular driving thing as you go higher in speed on the highway, etc. Is this what you guys have/do?
Old 10-18-2014, 05:32 PM
V12TTenthusiast's Avatar
06 SL65AMG, 13 Tesla Model S 60kwh, 02 Jaguar S-Type 3.0, 12 S550 4 Matic, 07 E320 Bluetec, 06 LX470
599 isn't bad for new. Do you have to splice the wires on this version?
Old 10-18-2014, 05:45 PM
cal1's Avatar
SL55, ML500 & Acura TL
Yes, it does exactly what you are looking for. In fact, it has two speed settings. The first raises the car back to 1/2 factory height and the second back to full factory height. The speed at which you set these is fully adjustable. For example. Say you dropped the car 1.2 inches. The first setting will raise the car back 1/2 or .6 inches. The second setting goes back to normal ride height above the speed you set. As the vehicle slows to below the speed setting, the car drops down again.
My car is set at 1.4 down in front and 1.2 down in back. At 10 mph or so, it goes up by .7 and .6 respectively. At 20 or so, it goes to normal ride height.
The perfect place for the remote:
Old 10-19-2014, 12:28 AM
Viper98912's Avatar
Well that's cool, I wasn't expecting the dual functions. Does the remote replace the pots on the inside of the cover?
Old 10-19-2014, 10:22 AM
cal1's Avatar
Yes. I never used to phone system.
Old 10-20-2014, 11:52 AM
goalie_k's Avatar
2012 GL350
Even cheaper here:
http://loweringmodule.com/index.php/...e-wremote.html
Old 03-23-2016, 06:05 PM
dinfung's Avatar
2013 R350
Originally Posted by goalie_k
anyone actually tried it?
http://loweringmodule.com/programa-v...e-with-remote/
Old 03-23-2016, 06:45 PM
cal1's Avatar
Originally Posted by dinfung
YES! that is the module I have used for 3 or 4 years. Me plus maybe a couple dozen R230 guys and another 100 or so W211 guys swear by it.
dinfung (03-23-2016)
Old 03-23-2016, 07:28 PM
dinfung's Avatar
2013 R350
thank you for the reply. this is good news. I just placed my order, cheers.
Old 03-23-2016, 07:56 PM
cal1's Avatar
Cool! let us know how you like it. I think it is the most versatile cost effective lowering solution.
By the way, if you did not know, the Renntech unit that sells for three times as much is simply a programa with Renntech's name on it.
The following 2 users liked this post by cal1:
dblankenbaker (04-20-2017), dinfung (03-24-2016)
Old 03-23-2016, 10:25 PM
Viper98912's Avatar
Programa seems to have removed the buy icon from it's page. Last price I remember seeing was 449 or 499 or something. Makes me wonder if they even make them anymore
Old 03-24-2016, 02:10 AM
dinfung's Avatar
2013 R350
Send them a email. Got a quick reply from them. They are back order for 3weeks. They actually open up the web site and let me order it. So now is just the waiting games.
Old 02-23-2017, 09:18 PM
Adam Chambers's Avatar
2014 C63 Sedan (SOLD), 2011 SLS Gullwing (SOLD), 2009 SLK55 (SOLD), 2015 C7 Z06 7MT, 2016 C450amg
Just installed the Programa tonight. I love it. Easiest lowering job I've ever done! Question though, will this put a lot of extra wear on the ABC system?
Old 02-24-2017, 12:35 PM
carguyshu's Avatar
2003 E55, 2003 SL55, 2014 CLS63, 2018 q50 Redsport, 1968 Camaro SS, 1999 Trans am Firehawk
no. the abc system is continuously opening/closing valves when driving. The height being lower will not put any additional stress on the system. As far as tire wear/handling/ride quality is concerned I would setup your module to return to stock ride height when you are driving (you can set it so that stock ride height will resume at a speed you set)
Old 02-24-2017, 06:41 PM
Yeah I have it set to lower all the way, 2". Then come up 1" at 3mph and full height at 6mph. Really just wanted it low when I parked it.
Old 02-24-2017, 08:27 PM
dinfung's Avatar
2013 R350
you guys are lucky. The go back to reg height option is not available for the R-Class. I did drive the R-Class for the whole summer with the front dropped at 1.25" and the back at 2". didn't encounter any problem at all.
Old 02-24-2017, 09:02 PM
cal1's Avatar
I'm guessing the R class cars are airmatic instead of the hydraulic ABC system used by the SL.
Old 02-25-2017, 04:54 PM
Finally took the car out today and it's not reading speed. Anyone else have this issue? Everything else works correctly. Shows 0mph and doesn't raise at specified speeds.
Old 02-27-2017, 02:46 AM
DUDMD's Avatar
2005 SL65 AMG, 04 S600
Mine did the same on the sl65, I tried swapping the can wires around as instructed by their tech support, it didn't help.
So I was just manually reverting to stock while driving/etc.
But I got rid of my entire ABC system before figuring out what caused it to not see speed, and will be selling my programa v2 as I'll be on coil overs very soon.
Old 02-27-2017, 07:49 AM
Thanks for the info. I will try swapping CAN wires. Thats the only connection that would provide speed. If that doesnt work its gotta be a programming issue in the unit.
Old 02-27-2017, 11:36 AM
latemodel21's Avatar
2003 SL55 / 2002 SLK32
I just noticed last month that I have this same issue with the programa Module in my 2003 SL55.
I don't drive it in the rain, so I have not looked into this further yet.
Chris
Old 11-04-2019, 12:46 PM
gqdabien's Avatar
SL63
I see now a v4 module is available: http://loweringmodule.com/programa-v...e-with-remote/
How does the lowering module affect the stock height adjustment button by the shifter? Lets say I set the lowering module to lower the car 2" all around and then i press the oem suspension height button (1 or 2 red lights).
Thanks!
Old 11-04-2019, 12:56 PM
Thanks!
your factory button will still work as usual.
Your car has a sensor at each corner that measures the height of the car ; this module modifies the signal for each corner sensor to change the height (while your car does not know the module is there and trusts the signal it is getting).
the real question is ... has programa fixed the modules inability to use the speed adjustable height feature? ... the link you posted does not mention is so my guess is ...no (but I would love to find out that they have)
Cheers,
Chris
Old 11-04-2019, 01:52 PM
gqdabien's Avatar
SL63
To clarify, if lowered 2" using the module. The low/medium/high factory height button will be 2" lower for all settings? Similar to how the lowering links work.
Old 11-04-2019, 02:28 PM
THe module does electronically exactluy the same thing as the links do mechanically (fool the 4 ride height sensors)
So, the factory button willl CHANGE your ride height exactly the same amount per button depression as usual . It (your car) has no idea that you have inserted the module. So yes you can lower your car 2" and the button will have the same effect as it does now.
But ... 2" ? really? I would be worried about the compromised tire life and handling ....
Best of luck,
Chris
Quick Reply: SL55/63/65/R230 AMG: Ride height limiting on the Programa lowering module V2 (ELM)
