SL55/63/65/R230 AMG: SL 55 malfunction
I have a 2004 SL 55 and i keep on getting a malfunction between time to time.
"Check tire pressure."
I always ignore it , it disappears and comes back between time to time.
did any1 have this problem? any solution ?
I dont think im low on air because when the malfunction goes away the pressure in all the tires is same but when it comes back i have different pressures in each tire.
thats weird
In fairness to the dealer, we split the cost 50/50
Why they don't build the extra price into the overall cost of the performance pack beats me
Funny lot the MB policy makers in Germany.
You just need to check the pressure and top up the tyres - hardly a dealer item unless you are completely incompetent from a car maintenance point of view. You should certainly not ignore the warnings, just as you shouldn't if you have chest pains.
The TPM is there for a reason and I recommend it. Since the SL55 places heavy loads on its tyres, it is vital to run them at the correct pressure to avoid over-heating and unless you are conscientious enough to check the pressures regularly, you need TPM to keep a watchful eye over it. Also, since the SL55 usually does not have a spare, any early warning you can get about a problem with one of the tyres will give you more time to get it fixed.
Another weird problem popped up this morning.
My A/C went dead , i pressed all the buttons and non of them seemed to work. i switched the car off and back on and it was still the same.
i ignored it until the afternoon and when i switched the car on every thing was back to normal.
Weird Car
