SL55/63/65/R230 AMG: Sc pully and crank pulley suggestions need help sl55 amg
Old Apr 19, 2016 | 05:10 AM
Juaniri's Avatar
Mercedes SL55 AMG - BMW X6
Exclamation Sc pully and crank pulley suggestions need help sl55 amg
Hey guys kind of new here and needing some advice i have an 03 sl55 that i order a s/c 72mm fixed pulley, can i run a 190mm crank pulley also?
I already order a heatexchanger and jhonsosn ic pump
I currently have a 77mm clutch pulley ecu flashed, tcu flashed from eurocharge secondary cats deleted and rasognator, 3 inch x pipe and 3 inch straight pipes
Old Apr 19, 2016 | 11:29 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to R230 AMG forum...
Old Apr 19, 2016 | 12:20 PM
Nor Cal SL55's Avatar
2012 E63 AMG
I would suggest talking with your tuner about that kind of set up. Eurocharged will give you good input.
Research threads on each type of pulley (SC & Crank) and you may find some answers there.
Most are not going that deep with pulley choices. There are supercharger inefficiencies and heat issues that will need to be addressed as well.
Old Apr 19, 2016 | 12:30 PM
Juaniri's Avatar
I talked to solo motorsports in atlanta ga they recomended me 77sc pulley as its is now and go with a 180m crank
Also i talk to craig hawkens buckhead-imports in atlanta, amazing guy craig by the way, he recommended me to 72mm fixed pulley, 82mm tb, belt wrap kit and to leave the crank pulley alone, with a good tune that I should see some power
Old Apr 21, 2016 | 12:41 PM
2012 E63 AMG
https://mbworld.org/forums/w211-amg/...alculator.html
Old Apr 21, 2016 | 01:13 PM
cal1's Avatar
SL55, ML500 & Acura TL
It appears you live in the Atlanta area. If I did, i would work with Craig and Buckhead motors exclusively. You might think about what your ultimate goals are for the car regarding mods. Increased boost via bigger counter or smaller SC pulley, cooling and a tune could be all you want. If you have plans for more mods after that, you might discuss it with Craig up front.
If I had a stock SL55 right now, the first thing I would do is install long tube headers and a tune. Of course this can create smog issues in some states. I think LTs create the perfect foundation for future mods or no more mods.
