SL55/63/65/R230 AMG: I love the SL55 but just want a bit more...
Old Jun 18, 2016 | 02:12 PM
PoCoAMG's Avatar
2018 E63S AMG
Want your opinions on this. I love my 2007 SL55 AMG. I love the power, looks, comfort, etc. I see so many people modding their SL's and I love following the threads. I want to keep mine stock because I have no complaints, but I do feel there are some items that can improve the car with little cost. I am thinking..
1) Shardul's Belt Wrap Kit. It just makes sense and I can feel the belt not engaging as quick as I would like.
2) Better air filters from K&N. Or another brand people have had success with?
3) Headers. I love the Eurocharged one's I see currently for sale. I would like to just have the manifolds breathe a little better.
4) Regular maintenance and over-the-top taking care of the car. Best fluids and regular maintenance. Really just looking after "Betty" and keeping her in top shape.
I bought a 2007 because I like the additional benefits from the slightly improved motor and I really love the Performance Package.
Cheers!
Shaun
Old Jun 18, 2016 | 04:35 PM
euphoriaDSM's Avatar
SL65 AMG
Start with a pulley, tune, and belt wrap kit. Also cut the secondary cats and resonators out, it won't be obnoxious loud but give the right battle cry when getting on it. If you need more after that then search for some headers and a FTP intake. Seriously the pulley and tune alone brings the 55 to life! I had a SL55 before my 65 and still miss the exhaust note.
Old Jun 18, 2016 | 04:54 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
What changes were made to the motor on the 2007 SL55?
Old Jun 18, 2016 | 07:30 PM
okbarnett's Avatar
Porsche guy who drives SL63 w/ perf pkg AND perf suspension
try bmc filters and mbh headers or look at renntechs stuff then a ecu program
Old Jun 18, 2016 | 09:24 PM
cal1's Avatar
SL55, ML500 & Acura TL
Long tube headers and tune. Best first mods IMO.
Old Jun 19, 2016 | 12:50 AM
PoCoAMG's Avatar
2018 E63S AMG
Thanks for the replies guys!
I see just a simple tune is good. I think the mods I listed may just make the stock motor a bit better (better engagement of the pulley, a bit more air flow and exhaust flow). Pulley and tune? It's just that little bit better. I get it. Cool
The 2007 has 510 HP and 531 torque (instead of 493/513). Upgraded supercharger. 80 mm throttle body instead of 74 mm. Slightly different tune to make up for the larger TB? (correct me if I'm wrong here).
Thanks guys.
Shaun
Old Jun 19, 2016 | 08:10 AM
kittyandgary's Avatar
2003 SL55 AMG
I'd forgo the K & H filters. Anything that let's more 'air' through also lets more dust/contaminants through. I want VERY CLEAN air going through the precision supercharger, and into the cylinder bores.
Just my opinion - YMMV (your mileage may vary)!!
Old Jun 19, 2016 | 02:19 PM
PoCoAMG's Avatar
2018 E63S AMG
Good point about the filters...
Isn't BMC a very good foam filter (no oiling). My car is a summer driven car only in Vancouver BC (similar to Seattle in climate) so little dirt (good roads here) but the best filter with most flow is what I'm after.
Shaun
Old Jun 19, 2016 | 04:59 PM
Nor Cal SL55's Avatar
2012 E63 AMG
Cheers!
Shaun
I just did all of this to my 2007 SL55 less the headers, including every fluid, brakes, tires, a full service on anything I could think of. Some things may not have needed it yet, but I wanted to make sure everything lasts a while on this car. Good maintenance and clean fluids can't hurt. I've had the car almost 6 years and maintained religiously with all the "A" & "B" services and everything that was needed under warranty for the first 50K miles (had an extended warranty that expired a year & a half ago).
I also recently installed a 77mm clutched pulley, ECU/TCU tune. I did a base line dyno before I did anything and the car was pretty dang impressive stock. I am scheduling a dyno this coming week to get numbers after all this new work. We'll see what the differences bring.
Best of luck with your car!
Old Jun 19, 2016 | 05:02 PM
2012 E63 AMG
Thanks guys.
Shaun
542cc injectors too.
Old Jun 20, 2016 | 08:43 AM
2003 SL55 AMG
Shaun,
Be careful with any filter that uses oil. IF the car uses a hot wire for airflow measurement in the Mass Air Flow component, that oil can - over time - coat the wire, producing incorrect measurements. Quite a few guys who had filters with oil treatment had that experience with the later model Porsche 928's.
Old Jun 20, 2016 | 11:37 AM
BlownV8's Avatar
Fortunately the 55/600/65 forced induction engines use a MAP sensor so it's not an issue on our cars.
Old Jun 20, 2016 | 01:52 PM
okbarnett's Avatar
Ive used bmc and k&n in every car ive had since the 80s and not had any problems. the bmc is either dry or dryer than k&n
Old Jun 20, 2016 | 05:06 PM
kbob999's Avatar
'20 X5 M50i; '17 Ram 3500; Golf Cart; Bikes; Scooters
I went with the smaller SC pulley and belt wrap. That was all it needed to make it perform a 'little' better, especially at the altitude in Denver. Air filters are stock.
Otherwise all filters and fluids have been swapped, as well as the crank sensor, shift lever lockout, and all of those little things that can leave you stranded.
I have run K&N before on other vehicles, but also feel they can let some dirt through, and this vehicle wants none of that!
Old Jun 20, 2016 | 05:16 PM
sgaar's Avatar
'06 E500, '99 ML430 and '07 SL65
If the OP wants more, get a 65!
Old Jun 20, 2016 | 05:59 PM
PoCoAMG's Avatar
2018 E63S AMG
Could not find one...
....and the price was too good for this SL55
I'm good with the power, just trying to improve upon perfection (to me anyway). Best car I have owned...
Old Jun 21, 2016 | 11:06 AM
sgaar's Avatar
Hey, as long as you enjoy and your are then all is
Hopefully the good weather has come to your part of the world.
Old Jun 21, 2016 | 03:33 PM
Noir230's Avatar
1992 400E, 1997 SL500, 2007 SL55 AMG, 2016 E400
I got my SL55 in March. I have put in K&N filters, replaced the spark plugs, got TCU and ECU tunes and a smaller SC pulley from Eurocharged and installed an oil catch can. The improvement in power is really noticeable and I'm happy with the money I spent.
I'm now thinking about a Quaife or Wavetrac LSD. Just trying to decide between the two.
Old Jun 22, 2016 | 12:41 PM
carguyshu's Avatar
2003 E55, 2003 SL55, 2014 CLS63, 2018 q50 Redsport, 1968 Camaro SS, 1999 Trans am Firehawk
The K&N will provide little if any gains, particularly on a stock or near stock car given that the air intake system is so well designed. For 1 or maybe 2 hp its not worth the risk of sending dirtier air into the engine.
Old Jun 22, 2016 | 12:51 PM
sgaar's Avatar
We had a Quaife group buy back in the fall and ended up getting them form the official re-seller in the UK. If you look around you will find that there is a company in the US that is selling Quaife LSDs but it is an older rev. that was initially designed for some GM cars. They just happen to fit some M-B diffs as well.
I don't know about Wavetrack but I would advise that if you do decide for Quaife, that you look at Birds Auto in the UK. James Bird is the guy we talked to.
Old Jun 22, 2016 | 01:38 PM
carguyshu's Avatar
The diffs were from SRT dodge/Chrysler products & not GM if memory serves me right.
Old Jun 22, 2016 | 02:07 PM
Noir230's Avatar
I have had K&N filters on two of my cars for years and have not seen any indication of dirt getting into the engine.
Thank you. I sent an email to Bird's.
Old Jun 22, 2016 | 02:22 PM
carguyshu's Avatar
Does that mean you tore down the engine & inspected it with gauges? You can run a car with no filters for a long time & it not appear to have any damage or indication that dirt got in. Try running a k&n in one side & an oem filter in the other & see how much more dirt the oem filter stops from getting into your motor.
Old Jun 22, 2016 | 02:57 PM
Noir230's Avatar
No I haven't, but since you are the one making the assertions, what research have you done, or what studies can you cite, to show that dirt is getting into the engines? Have you had K&N filters and have you had a bad experience with them?
Old Jun 22, 2016 | 03:10 PM
sgaar's Avatar
Yep, that's the one.
