SL55/63/65/R230 AMG: SL600 / 65 AMG V12 Biturbo CAI system
https://mbworld.org/forums/sl-class-...ai-system.html
I was able to put down 602whp (780hp crank) with maxing out the turbos, tightened waste gates, icebox, intakes and downpipes, and race gas with a lot more timing with a custom dyno tune. There is no way these turbos can support an extra 125whp, not even with billet wheels on a properly working dyno dynamics without manipulation by user.
The dyno was an accurate Dyno Dynamics and we run 3 runs an the power level was between 525-533 kW.
I dynoed the car at another dyno to. The best torque was 1258 Nm ( 927 ftlb) / 2750 rpm.
So I don't think the booth dynos was manipulated at al.
I have a little more in there because the power curse drop a little at the upper rpm range and then rise up again. I must change bigger SL65 injectors because I think its run to lean.
I have stock turbos...
I guess you knows at SL600 the pump is outside and at the SL65 inside the tank. So you have the new pump inside the tank?
Thank you...Yes... its the best setup you can buy for sure. The finish also.
Thought that they are totally different.
What kind of tune do you have at car because you had to change the pump and injectors to?
Power level?
My old SL600 had a Evotech ECU-Tune, Crank-Power was 610 HP on a MAHA-3000 Dyno. Stock Injectors. Oliver changed my fuel pump to SL65 Pump because I had TOP-Speed of 330 KM/H and I drove it that faston the German unrestricted Autobahn.
He said at this sustained high-speed driving the Sl600 Pump delivers not enough to be safe. SL600 was always limited to 250 KM/H from MB so there was no need for the big 65 pump in stock form.
There is just no way you can get another 100+ whp from it on the same dyno, unless the units are not correct and actually show 525-533whp - which for an sl65 with bolt ons and tune is actually right in the ball park for a dyno dynamics. I was able to make 551whp on pump gas on a cooled down engine with a perfect amount of ice in the tank.
BTW: My sl65 stock put down 464whp on my dyno dynamics that was for 604bhp crank, with 602whp that puts it to 780bhp crank.
Can you post your dyno graph maybe?
There was, as you guessed 525-533 KW at the the Crank which is 714-725 PS/HP at the crank but NOT WHP.
So I think it is within his readings. We in Europe mostly measure in Crank-Power, which is obviously different than in the U.S.
One other Little Point: WHP to Crank conversion is complicated without measuring the real losses with a professional dyno. Can not simply be done with a certain percentage.
Difficult to to say that before the Tuning the losses were 140 HP Crank and after the Tuning the losses are lets say 180 HP Crank.
I would assume that if the number before the Tuning you mentioned is correct for a Stock car, then 602whp is less than 780 BHP. Because the losses should normally not rise that much like the power rises with the tuning. simply spoken.
So lets see if you can get another real 100 HP with the bolt ons on pump gas, I have my doubts, but best of luck.
On my 602WHP to 788 crank hp, that's really the only fair way guess crank numbers. It's still very close. Even if the 140WHP gains on my car didn't account for any loss, that would still put the crank hp to 740hp, but the drivetrain loss is still there. So really anywhere between 740-780hp is a good estimate.
My dyno reads really low, and almost any stock car we dyno, a 1.31 mulplier gets right on the dot of crank hp perfectly. So while I know what amount of power we gains exactly to the .1 of HP, we always multiply by same factor as factory to whp loss.
I have also something else that no one else has ever had.
I have modified the whole intake.... not only the CAI. That is also why my best torque is as low as 2750 rpm. 1258 Nm / 927 lbft.
I have dynoed the car in two different dynos. Nearly the same power range in both.
AMG Driver.
(Cant find any fuel flow charts for SL600 fuel pump).
Can you ask your tech one question regarding the SL600 fuel pump. I know you have an SL65 today. I have try contact Pierburg but no answers.
The OEM SL600. I have measure the pressure and it's show at idle and at 1,5 bar boost the same pressure. 3,8 bar.
Normally, the pressure should increase by the same amount from 3,8 bar to 5,3 bar. I don't want waste money to buy a new pump if the pump its not broken. The SL65 Fuel pump charts show its gone do that. From 13,5 Volt 300L/h to 20 Volt 360 L/h.
I'm 100% sure I need more fuel. Its run to lean after 4600 rpm and starts knocking and change the timing from -7 to -10 at 4800 rpm to -34 al the way to 5250 rpm 725 hp.
Thank you.
-Juha
The intake modifications made a lot and therefore I have this problems.
So next step is SL65 injectors for sure but I'm not sure if it enough. Maybe I need the SL65 fuel pump also.
Hope Speedriven / Marcin can help me out.
