SL55/63/65/R230 AMG: Ventilated Seats
But it might be problematic for your battery - if the ventilation is on even if the motor is not running.
Regards,
derMaximilian
Maybe my english-skills aren´t THAT good, as it´s not my mother language.
I meant the following: As soon as you insert the key, the appliances like AirCondition, TV etc. start working. If you override the switch for the ventilated seats, they would also start running, even if the motor isn´t on... and they would drain the battery.
Better?
Thx SL Boy!
In additon, the air conditioning takes huge amounts of power, while tiny fans in the seat do not use much, I would say less than the sound system. THerefore you can go quite a while with it running until the battery goes flat. This wouls therefore not be a problem unless you like to sit in the car with the engine off all the time.
