SL55/63/65/R230 AMG: What the hell happened?! (stupid mistake, possibly complex problem)
Fast forward to a few hours later and I completed my daytime running lights project and they work fine. However, the car is messed up now and won't start. In key position 1, everything is normal. When I click to key position 2, the engine cooling full comes on immediately and at full blast/power. I get a few error messages in the gauge cluster saying "display faulty visit workshop" and "ESP, ABS, ABC". Turning the key to the on/start position does nothing. As soon as I take the key back to position 1 or remove it completely, the fan engine fan stops immediately.
I should add that power windows, headlights, lock/unlock button, fog lights, electric seat adjustment, keyless go button, heated/pulse seats, radio, navigation, keyfob lock/unlock, trunk release, steering wheel tilt/telescope, etc all still work fine and normal. I can still lock/unlock the car from the keybfob as well.
From what I've read, the engine cooling fan will come on at high speed whenever the ECU is inactive or not sending a signal. I have a Eurocharged tune on the car and tried to "re-flash" the ECU tune hoping that it may of just gotten corrupted or erased. However, I get an error saying "unable to contact the DME, please make sure that it's properly powered on". I then tried checking the codes with STAR/DAS, erased them, and then tried checking again. The results are below. I checked every fuse in the passenger and driver's side SAM and they are all ok. I'm not sure how to tell if a relay is bad though just by looking at it? Also, I tried disconnecting the rear consumer battery and unplugging the ECU for 10 hours with no change.
So that's my story. I'm hoping that my amateur mistake didn't fry all of my car's electronics. I would think that they are fuses/relays to prevent this type of thing from happening though?
Any thoughts/suggestions that I could try before I tow the car to the dealer?
I should also add that I tried swapping relays in the passenger SAM with no change as well. It looks like relay "K" controls the ECU and that's the one that I accidentally shorted. I also can't move the shifter out of park since the EIS fault code is current.
My only guess is that the ECU software/programming is now corrupt. I was thinking about mailing the ECU back to the tuner for their inspection and to have them bench flash it again if that's the problem. Is the ESP handled by the ECU or TCU? Other than that, I'm out of ideas?
The ME-SFI can communication fault is saying that there is a communication problem with the ECU, which is why the fans are defaulting to full blast as it is the default protection mode.
you also have CAN communication with the gear selector (the car wants to make sure it is in park or neutral before it will let you start it), the speed sensors (likely the transmission ones), the esp, the distronic module (on the early cars this was next to the TCU, but I think it later cars it is built into the sensor).
The ! signal next to the ESP and ME-SFI is saying that STAR can't even communicate with either of these modules at all.
I couldn't get the car to turn over because the screen said "car not in park", when it was. Similar codes were present as yours... ESP, ABS, MF-SFI, etc. You definitely have a communication issue.
Take it to MB and have them fix it - unless you know of a GOOD Indy shop. I lost faith in the one I was going to. Saving a few bucks can cost you with these cars on electrical issues.
everything is working again
Chris
