SL55/63/65/R230 AMG: Has anyone upgraded their head units to the Android Chinese Models?
Old Apr 28, 2018 | 06:40 PM
lagolag's Avatar
SL55 AMG 2003 V-Max
Originally Posted by Austinsec
Here is a picture of the wire what end did you cut , witch end is the front ( I assume the one with the white connector is the front, didd you use the white
connector or did you use the short cable one)
I assume end marked 1 and 2 are the front since connector 1 is the same as canbus and connector 2 fits into new head unit.
Picture is missing
Old Apr 28, 2018 | 06:42 PM
Austinsec's Avatar
Sl55 2003
speaker wires
Here is the issue I have the front side done , I am at a loss on the back end, I have noway to figure out the speaker wires from the amp, I am unable to read the diagram
on the internet. My connector is the same but wire colors are different so I have no clue as of yet.
I am not doing a new amp for now want it working here is a pic of the connector
Old Apr 28, 2018 | 06:57 PM
lagolag's Avatar
SL55 AMG 2003 V-Max
Originally Posted by hamann1000
I'm about to pull the trigger and buy one of these. Did the optional 6m long main cable help at all for the install? and overall, are you happy about getting this deck? Thanks
As all connections to the speakers is located behind the drivers seat where the amplifier sits, you need to route cables between, and it's about 15 leads, for me the long cable made it easier.
As I wrote before the sound with my set up is in the same level as the original Bose set up and it looks original, and it is nice to have some buttons and knobs to control the unit easy.
Old Apr 28, 2018 | 07:00 PM
lagolag's Avatar
SL55 AMG 2003 V-Max
You have it all in the PDF file I attached with the picture
Old Apr 28, 2018 | 07:10 PM
lagolag's Avatar
SL55 AMG 2003 V-Max
The rear speaker is in 10- and 18+
Old Apr 28, 2018 | 11:26 PM
theboogers's Avatar
2020 S560,14 ml350, 03 sl55, silver, pano, slr cams, evo headers, lsd, 2019 s63 cab.
I have a 2003 sl55 in phoenix az area. Anyone know a good shop they can refer to get a stereo system like this changed from stock? Thx
Old Apr 29, 2018 | 03:12 PM
  #32
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
This seems to be incorrect. According to Mercedes' troubleshooting schematic the rear speakers (+) terminal is wired to socket 10 and the (-) is wired to 18. You also have the left-door tweeter similarly out of phase.
There is a problem to address that seems to have gone without mention. The factory amplifier has 7 channels of amplification to drive 8 speakers. I presume a Chinese head unit has 4 channels...
Old Apr 29, 2018 | 06:55 PM
  #33
Austinsec's Avatar
Sl55 2003
ok , I got it working, anyone else have an issue with reception?
Old Apr 30, 2018 | 01:05 PM
  #34
Austinsec's Avatar
Sl55 2003
Anyone know how to correctly connect the antenna mine came with a long cable but one end looks like gps not plug in. when I just use the one that is in the car
it it not the best reception.
Old May 1, 2018 | 12:29 AM
  #35
hamann1000's Avatar
sl55
so it looks like you can make this apple iPhone integrated with this adaptor seicane offers. does anyone have this? its another main reason I'm considering it
https://www.seicane.com/plug-and-play-carplay-usb-dongle-for-android-car-radio-support-ios-iphone-car-touch-screen-control-siri-microphone-voice-control-s01001
Old May 6, 2018 | 01:36 AM
  #36
hamann1000's Avatar
sl55
well I received the receiver from aliexpress today and bad news, I cant even get the unit to power on, I connected the 12v yellow and the blk ground and nothing, am I missing something here or I may of got a dud
Old May 6, 2018 | 08:19 AM
  #37
Austinsec's Avatar
Sl55 2003
yes you have to connect the cambia box and the adapter with the 4 wires 2 green 2 white
had same issue it also took a few minutes to power even with those and would shut down after a few unites. Once all wires are connected it’s works except for reception of radio
Old May 6, 2018 | 09:00 PM
  #38
hamann1000's Avatar
sl55
thanks, got it on now. That's so weird that little wire needs to be connected for it to be turned on as the long wire doesn't have it. Just in case I have reception issues I bought a radio booster off ebay for like $5 and will throw it on to see if it makes a difference. Ill keep you posted as I get started on my install
Old May 6, 2018 | 09:43 PM
  #39
Austinsec's Avatar
Sl55 2003
I got the booster too did nothing except extend the cable needed that
Old May 6, 2018 | 09:44 PM
  #40
Austinsec's Avatar
Sl55 2003
Btw drove the car today reception is non existent unusable at all
Old May 6, 2018 | 09:49 PM
  #41
hamann1000's Avatar
sl55
Where did u mount the gos and WiFi antenna? I don’t know how strong of a reception they have I just want them both to be out of sight
Old May 6, 2018 | 10:09 PM
  #42
Austinsec's Avatar
Sl55 2003
honestly I did not mount them yet as the FM is most important , I can mirror link waze if I need too from phone
Are you in the USA too?
Old May 6, 2018 | 10:14 PM
  #43
hamann1000's Avatar
sl55
Yes, after I get a speaker hooked up ill see if and let u know if I have any luck with the radio
Old May 6, 2018 | 10:30 PM
  #44
Austinsec's Avatar
Sl55 2003
great thank you
Old May 8, 2018 | 01:20 AM
  #45
hamann1000's Avatar
sl55
great thank you
so far I have half of the speakers goin and I used the small radio adaptor (not the one with the long wire) and connected that to my factory antenna that came off my oem deck, worked perfect, my cars in the garage but I got fine reception. Have you tried that?
Old May 8, 2018 | 01:25 AM
  #46
hamann1000's Avatar
sl55
I also bought a tpms and apple carplay for it that I will route into the armrest (if they ever arrive from china). So far I'm really impressed with this deck, its like a computer, I was able to get on websites and seems like it has tons of functions and options. I'm doing it without tapping any of my factory wiring, don't want to splice any of that up wiring up so I'm using .110 spade connectors to plug into my amp harness.
Old May 8, 2018 | 01:42 AM
  #47
hamann1000's Avatar
sl55
I'm wondering if I can use something like this to use the factory gps antenna so I don't have to run the one that came with it
https://www.kufatec.co.uk/shop/en/mercedes/c-class/c-class-w203-cl203/mercedes-gps-antenna-adapter-aps30-comand-2.0
Old May 8, 2018 | 07:47 AM
  #48
Austinsec's Avatar
Sl55 2003
I used the adapter not one station is clear enough to listen too, the static and interference is unbearable
Old May 8, 2018 | 11:59 AM
  #49
lagolag's Avatar
SL55 AMG 2003 V-Max
Now I’ve been out driving and the reception is not in the level of the std unit, it’s very bad when driving in parking garage for example.
As soon as the station gets week it start to search, can’t find anything in the settings to prevent it. Worst for me is that 107.3 is almost impossible to listen to, one of the popular frequencies where I live. I know that US freqency steps is different from Europe, can it be so there is a EU FM tuner instead of US FM tuner, I don’t know if that is a SW thing these days.
I have conncted the original antenna connector to the HU using the antenna adapter that came with the kit.
What I find more disturbing is the difficulty to read the display, the backlight is very week during daylight, night’s no problem.
The twin USB can I only use for charging the phone, there is no acces to the stored music on the phone, neither can’t I play music from a USB memory.
Mini SD with music on installed in the DVD SD slot works perfect.
Internet radio works greate and that is the most important thing for me.
I must sort out the backlight issue, any Ideas out there?
Old May 8, 2018 | 01:06 PM
  #50
Austinsec's Avatar
Sl55 2003
My reception is literally unusable I cant keep this radio ,
somthing has to be wrong I will try external antenna again
if it does not work i have to return and move to the next radio
