SL55/63/65/R230 AMG: SL55 AMG - S/C Pulley is Goning Bad. Upgrade or Stock?
Old Dec 22, 2017 | 03:22 PM
HeatGun's Avatar
SL55AMG
Hi all,
I just bought a SL 55 AMG and realized that S/C pulley is missing ball bearings and making weird noises..
Looks like I am due for new S/C pulley. I see that people are upgarding their pulleys to 77mm or smaller than stock one.
Do you guys recommend pulley upgrade or just keep it stock 87mm?
What brand pulley do you guys recommend? I see lots of different options online with minimal reviews.
Do I have to do ECU mod after replacing pulley? I dont have much time these days I just want to get pulley replaced and be on my way, if upgrade is OK and wont harm anything then where do buy upgraded version? Is there any other upgrades do I have to do in order to keep S/C safe or cooler?
This is a reference photo I found online. Pulley in my car looks exactly the same with missing ball bearings.
Old Dec 22, 2017 | 04:29 PM
Noir230's Avatar
1992 400E, 1997 SL500, 2007 SL55 AMG, 2016 E400
If you want to stay stock and save money, just replace the bearings. They're sold on eBay.
Old Dec 22, 2017 | 05:00 PM
HeatGun's Avatar
SL55AMG
Oh... never thought about this. Will order OEM bearing from eBay. Thanks!!!
i just bought the car as I said, my daily driving car is Prius so from Prius to this already a big difference. I would like to enjoy this car as it is with stock parts then I may do some HP upgrade as I use
Old Dec 22, 2017 | 06:21 PM
Noir230's Avatar
YouTube has videos on how to replace the bearing.
Old Dec 22, 2017 | 06:30 PM
HeatGun's Avatar
SL55AMG
watched a few already and ordered following one from eBay. Here is the link in case anyone else wants to do same repair
https://www.ebay.com/p/MERCEDES-E55-AMG-OEM-Nachi-Supercharger-Clutch-Pulley-Bearing/1426893465?iid=142267813518
Old Dec 23, 2017 | 11:01 AM
idrive's Avatar
2017 SL63
Be sure and check the belt. If it's the original this would be a good time to change it.
Old Dec 24, 2017 | 11:16 AM
560 SEC's Avatar
2011 S550
You can buy a smaller 83mm pulley from Eurocharger for around $400. That's what I did.
I also changed the bearing on my stock pulley, just make sure you don't a cheap chinese knock off.
Old Dec 26, 2017 | 06:55 PM
HeatGun's Avatar
SL55AMG
Okay ay here is the update.
I a had mechanic to remove pulley from the car. I will swap bearings later today and bring pulley back to shop tomorrow so he can install but here is the issue. I am not sure how this has happened but those two pins broke while he was trying to remove screw from pulley.
should I be worried about this? What is the purpose of these pins? It seems like like they hold washer in place but does it really matter?
Old Dec 27, 2017 | 04:07 AM
560 SEC's Avatar
2011 S550
Mine did the same thing, no problem.
BTW, use some sandpaper and clean the rust up on the mating surface
Old Dec 27, 2017 | 10:10 AM
VictoryRoadPerformance's Avatar
SPONSOR
E55 C63
Happens all the time, no need to replace them..
When you're Ready check out our 76mm pulleys.
We also have the replacement bearings available on our website
Old Dec 27, 2017 | 11:41 AM
kittyandgary's Avatar
2003 SL55 AMG
Don't know how many miles are on the SC, but you might consider changing the oil in the SC, since the life of the pulley bearings had been exceeded! Need about half qt of Mobil Jet oil and a medium sized syringe with small tygon tubing for the job.
Welcome to the pond.
Gary
Old Dec 27, 2017 | 11:43 AM
HeatGun's Avatar
SL55AMG
Gary
Car got 90k miles on.
I am changing engine oil, drive belt, SC pulley bearing and SC belt today but thank you for heads up. Will change SC oil as well
Old Dec 27, 2017 | 11:51 AM
560 SEC's Avatar
2011 S550
Take your time and make sure you get all the SC oil out. You need to keep repositioning the tube to get all the oil out.
It's about 100ml total
Old Dec 27, 2017 | 06:15 PM
HeatGun's Avatar
SL55AMG
Today my tech installed the pulley with new bearings, all worked out pretty well.
I had him to change drive belt, SC belt, engine oil and oil filter.
He added exactly 8qt 0-40 Mobil 1, right after I left his shop I got “Engine Oil Leve, Reduce Oil !” warming at dash. Warning comes and goes. I say it comes about 30 mins after start driving and stays on for about 5 mins then goes away.
I parked the car, let it cool down for 30 mins and check engine oil level while car is in DYNO mode and car shows 8.1 qt oil.
I did not check oil level prior changing the oil, never had that type of warning though. I dont car does not have too much oil in there,
There is no coolant leaking or anything.
any thoughts?
Old Dec 28, 2017 | 05:50 AM
560 SEC's Avatar
2011 S550
It takes 9 qt's
Old Dec 28, 2017 | 07:20 AM
HeatGun's Avatar
SL55AMG
Originally Posted by 560 SEC
It takes 9 qt's
I know this but dash warning tells me to reduce engine oil, does not tell me to add oil even though there is 8 qt oil only.
Old Dec 28, 2017 | 09:50 AM
latemodel21's Avatar
2003 SL55 / 2002 SLK32
perhaps he did not get all of the old oil out. Did he remove BOTH drain plugs?
welcome to the forum,
Chris
Old Jul 14, 2019 | 05:03 PM
Mr.Mopar2's Avatar
2005 SL55 AMG
Exactly what mine looked like. I was able to replace the bearing only for $60. Removed the bearing with a large bench vice and bushing. Installed new bearing by freezing the bearing and heating the clutch to about 250 Deg. Re shimmed to spec,, and works great. PS, it is not missing bearings as each ball has a specer in between, but the dust shield is gone and so are the spacers. Since you still have more than 180 deg if bearing contact, no damage should have occured to the supercharger. My dealer wanted to replace entire supercharger fearing it had lost the *****. to the tune of $6500. Check the idler and the tensioner pulleys for wear also.
Old Dec 31, 2019 | 11:06 AM
850csi's Avatar
--sold Sl55--
Guys, I’m hearing some chattering from the area of my supercharger.
And I found small, broken pieces of plastic in the bearing, next to the ball bearings. Some appear to be missing.
I assume I just need to swap the bearing out?
Old Dec 31, 2019 | 12:26 PM
SPONSOR
E55 C63
Sounds like a Perfect opportunity to upgrade the pulley, If not you can purchase just a replacement bearing aswell., https://www.vrpspeed.com/product/nachibearing/
