SL55/63/65/R230 AMG: quick few questions about the 6.0
Old Jan 11, 2018 | 07:29 AM
dohcfiend's Avatar
2001 CLK 55 AMG.......... 2001 Corvette Z06.........
so out of random curiosity...........is there a major difference between the fire-breathing v12's such as the ones that come in the SL65 AMG and the n/a ones that came in the previous generation SL600's?
I am mainly curious about the construction of the block and heads so in theory(all tuning aside) if I took one of these engines and boosted.......would it be as reliable at the same power levels as the SL65AMG?
Secondly, does anyone have any idea how it compares in dimension to the mercedes 5.5 v8?
I see the 6.0 will interchange with the 5.5L in the SL platform but what about a tighter platform such as a CLK that came with a 5.5?
Old Jan 11, 2018 | 11:20 AM
braddman's Avatar
2005 SL65 AMG
The previous generation non forced induction V12? If that's what you mean then no, it is not at all suitable for boost. The best you could hope for with amazing luck would be 4-6psi of boost on this thing without destroying it and no you're not going to make 600+ reliable horsepower from this engine. Stock it makes 389hp. The SL600 makes a lot less boost on the V12. The 65 runs 21 psi.
Second question you're not getting the V12 into a CLK without a major major revision or reconstruction. Highly doubt it especially with boost. It barely fits in the SL65.
Old Jan 12, 2018 | 12:33 AM
dohcfiend's Avatar
Thanks for the fast replies and help with things. I figured as much or someone would have performed the swap already. thanks guys!
