SL55/63/65/R230 AMG: Long Distance buying - Advice
I'm in Chicago and after almost a year of looking I found a 2009 SL63 in Tarpon Springs, FL on ebay from 2nd owner, 43k miles, maintained at the dealership car was posted with buy it now $30k and currently bid is at $20k if i can get the car for less then $30 that would be great deal as the same car in Chicago would cost around $40k.
So here is my question, does any one recommend a good mobile inspection service? I would love to have someone inspect the car and if everything is fine get the car shipped to Chicago.
any ideas, recommendations, suggestions would be greatly appreciated
Thank you!
I'm sure you done your home work so you hate to get one with a head bolt issue or leaky ABC system. Both can be pricey to fix if your not wrenching on it yourself. But even little things can add up quick like brakes with maybe only 25% left or tires at 30% life left.
Spend a few hundred on PPI is well worth the peace of mind.
How can one spot issues with headbolt? is it something that can be seen by looking at the engine or the engine has to be taken apart ?
Talk to the service mgr, ask him to look at the master enquiry, its complete service history at MB. Ask to give you all that info. Ask if ever had or needs bolts and also a lifter tapping issue.
You may spend another $20k on the car if you buy it w/out finding out all this before you buy it
I do believe if you do some research I think some have replaced these bolts without tearing apart the motor and costing a lot of money.
Option 2, fly down to Florida and take the car to MB with the seller. If it checks out, buy and drive it home. You'll save the $800 bucks to ship and It will be the best 2 days of ownership!
