SL55/63/65/R230 AMG: Im about to give up on my andorid radio please advise
Old May 9, 2018 | 11:31 PM
Austinsec's Avatar
Sl55 2003
I just installed a seicane android 7 radio get not usable reception in the USA New York ,
I am leaning towards returning it and getting something else any advise must haev good reception,
i live less than 20 miles from a station an cant get it clear. I connected the 12v blue wire for the amp no help
also bought the amp thing on ebay no help
what should I do?
Old May 10, 2018 | 12:23 PM
latemodel21's Avatar
2003 SL55 / 2002 SLK32
what should I do?
have you tried an external antenna?
Old May 10, 2018 | 01:01 PM
Austinsec's Avatar
Sl55 2003
Yes even worse than the factory one
Old May 12, 2018 | 04:10 AM
hamann1000's Avatar
sl55
Mine works great, I added the booster from ebay and the radio sounds better than the factory one. Maybe wrap electrical tape around the adaptor, not sure but maybe its possible something is shorting it out, or maybe you somehow pinched or cut your original (weird things can happen when you try to get the unit all the way back with all the wiring this thing comes with)
Old May 12, 2018 | 04:14 AM
hamann1000's Avatar
sl55
also go through the radio settings, I think I may of messed with the settings or input the US for my country. If nothing else I know there is something called the DAB radio that is a add on, maybe try that
Old May 12, 2018 | 08:30 AM
Austinsec's Avatar
Sl55 2003
In the us fab is not used and I checked the setting it is USA
Old May 15, 2018 | 02:34 PM
lagolag's Avatar
SL55 AMG 2003 V-Max
I don’t have bad reception but the radio refuse to stay att selected station so I contacted my seller and he came back with following to sort out my problem and so for it made my problem to disapear. The instructiom follows in below window. There is also part of my dialogue with them.
lagolag's Avatar
SL55 AMG 2003 V-Max
Old May 15, 2018 | 02:45 PM
Austinsec's Avatar
Sl55 2003
Reception
I am in the USA I tried everything every setting I get the stations but no well enough to listen too so much static and noise . I bought a external
ante still no help
Old May 15, 2018 | 04:47 PM
lagolag's Avatar
SL55 AMG 2003 V-Max
That you are i n US is obvuious from your profile shown next to your posts, but it was not obvious that you had access to the info I provided and of cause you should select whats correct for where you are on the Globe.
So you where aware of how to enter in to the Settings menue with it's log in code already, I just tried to help.
And you're telling that it is worse then the factory one, I take that as you had bad reception already on the std MB Headunit as well, in that case you've got a antenna problem in your car.
Old May 15, 2018 | 05:01 PM
Austinsec's Avatar
Sl55 2003
I had great reception on the factory unit . I bought this as an upgrade. No channnels work good enough to listen to. I do have access to that menu tried all settings US and otherwise. I bout ham external antenna it is even worse than factory. I did connect the blue wire as recommended without it horrible reception within slightly better. He are sending me some part to replace inside the radio fm module or something. I am holding out hope. I do use fm and am most but wanted Bluetooth and better nav. If you have any other suggestions let me know
Old May 16, 2018 | 05:35 PM
lagolag's Avatar
SL55 AMG 2003 V-Max
Does your Steering wheel buttons work as it should, mine only works for sound and station change and when i use the menue buttons it also change station, have yo similar problem as well? The phone button worked before I was in to the factory setting menue to get the radion to hold the stations before the search started automatically. Can you se what setting you have in the factory settin under Canbus? Appreciate if you could upload a picture of how it looks.
Old May 16, 2018 | 06:16 PM
Austinsec's Avatar
Sl55 2003
same thing as yours
Old May 20, 2018 | 07:58 AM
IM__FIT e55's Avatar
06 E55 Bea55t(gone) 03 Sl55 Mon55ter, 07 S550
I'm also in nyc. Who installed your radio? I'll be willing to buy it from you. Pm me
Old May 20, 2018 | 07:59 AM
Austinsec's Avatar
Sl55 2003
I did was not hard once I got instructions.
but cant even hear 103.5 clear.y
Old Jun 16, 2018 | 06:35 PM
lagolag's Avatar
SL55 AMG 2003 V-Max
I have no sorted out the issue with the Steering Wheel switches.
The settings on the CAN-bus box should be set to ”Old S-Class” and the everything works as it should.
Old Jun 25, 2018 | 11:23 PM
Austinsec's Avatar
Sl55 2003
how is the reception?
Old Sep 29, 2018 | 12:31 PM
vnova94's Avatar
2012 ML-350
Did you ever get this resolved? I just purchased one from CarNaviPlayer and i'm dealing with the same issue. I purchased a booster... helped a little bit but connecting the power wire had absolutely no effect... so i had a second one sent. Same thing. Was thinking about getting an external antenna to tuck inside instead of using the windshield antenna.... Well, i tried an external antenna and it was worse than the booster on the stock antenna. I've run out of ideas.
Old Oct 8, 2018 | 11:02 PM
Ed954's Avatar
R230
We just gave up on ours in ml63. All these Android units are crap. We had Avin one and there isis reception whatsoever, support won't give us a code for the radio. Google auto is not compatible. Constant glitches... Next time only branded units for us...
