SL55/63/65/R230 AMG: Steering wheel
Old Jun 7, 2018 | 12:44 PM
TT SL65's Avatar
SL65
Steering wheel
I recently purchased a 2008 SL65 AMG and the seller gave me this steering wheel as part of the deal. It is Alcantara on the sides and middle and has the flat top and bottom. I think I will leave my car stock for now. Just curious if anybody knows where it came from or what something like this is worth?
It has the paddles on the back but says Airbag on the lower part of it, not AMG. Thanks!
Old Jun 8, 2018 | 12:10 PM
latemodel21's Avatar
2003 SL55 / 2002 SLK32
it likely is a wheel for a 2009-2011 R230 that someone had modified and re-covered. The air bag may or may not be R230 compatible (SLK and CLS used an identical looking bag that is electronically NON-compatible). The part number on the bag will tell the tale . It will likely read A230 860 XX02 if "XX" is 12,13,25, or 26 it is a CLS bag ... if "XX" is 11 or 24, it is an SLK bag (and, if it starts with A219 or A171 then is it also a CLS or SLK bag respectively).
hope that helps,
Chris
Old Jun 9, 2018 | 11:51 PM
TT SL65's Avatar
SL65
Yep, the airbag is a "25" so it is not worth anything. Thanks for the help. I think I may mount it on my UTV!
Old Jun 10, 2018 | 12:09 AM
It is not entirely useless, it will work in a CLS or, can be used in an R230 if you switch the electronics (N135) that is built into the other side (you would have to salvage it from an R230 airbag that has deployed . Don't toss it ... I'll give you $100 for it (the bag that is ... you keep the wheel)
Chris
Old Jun 11, 2018 | 10:24 PM
TT SL65's Avatar
SL65
Chris
Ok, let me remove it from the wheel and make sure it is ok. I will take a few more pics of it and post.
Old Jun 13, 2018 | 12:55 PM
you can email me at latemodel21@yahoo.com if you like as well.
Chris
Old Jun 15, 2018 | 11:19 AM
TT SL65's Avatar
SL65
Email sent
Old Jun 18, 2018 | 11:57 PM
Ed954's Avatar
R230
Pm'd you.
