SL55/63/65/R230 AMG: SBC warranty extended to 25 years
Old Sep 1, 2018 | 02:05 PM
ItalianJoe1's Avatar
2003 CL 600
Originally Posted by FxFormat
SBC is a safety concern, ABC is also a big safety concern for the public. A ruptured line spilling hydraulic fluid everywhere ought to be a hazard for other drives as well as yourself losing control of the vehicle. Something like this should also be considered for warranty, esp when i've seen cars ruptured their lines rather early on and with low mileage.
Bring a lawsuit against MBUSA, I'm sure that's what happened for the SBC extension originally. Prove the same issues exist with ABC and see how it goes.
Old Sep 1, 2018 | 05:11 PM
FxFormat's Avatar
SL 600
Not sure if you guys saw this on the other forum, but an SL500 Accumulator exploded and shot out the side of the car.
Old Sep 1, 2018 | 05:35 PM
jimonqa's Avatar
2003 E500, 2004 E500 4matic, 2008 E550 4Matic
Regarding reimbursements for SBC repairs before receiving the warranty extension letter: They are, but if it was 3rd party they say they "may/might not".
Old Sep 6, 2018 | 10:29 AM
bizzy247's Avatar
'06 R53
Is that from the SBC exceeding limits or the brake pad wear sensors hitting the rotor.
It was definitely SBC related since they measured my pads at 10mm.
I made an appointment and dropped the car off at Mercedes of Downtown Los Angeles on 08/31/2018. They loaned me a courtesy vehicle through the long weekend even though I offered to bring the car back on Tuesday since they don't service these type of repairs on Fridays/weekends and Monday was a holiday. I got a text on Tuesday saying the car was ready to be picked and I picked it up on Wednesday. The service tech said all that was necessary was a software reflash to remedy the issue. My friend with a similar vehicle (E320 CDI) had a red message on the dash and his vehicle is having the accumulator replaced.
Old Sep 10, 2018 | 03:50 PM
jimonqa's Avatar
Supposedly, the SBC end of life is a concern so they trigger the warning after the number of uses reaches a safe threshold to avoid catastrophic failure. When they did your software re-flash, it sounds like they zeroed out the counter which appears to be an irresponsible way to address the issue, leaving you at risk for a future failure. However, maybe it was something other than reaching the threshold, in which case their repair may have been appropriate. I guess it depends on your mileage... if it is high (near 90,000+) then I'd be concerned.
Old Sep 13, 2018 | 03:59 PM
cal1's Avatar
SL55, ML500 & Acura TL
Well, glad to see some of my old buddies still active here. I just received my letter from MBUSA regarding the extended warranty on SBC components. A couple years ago after much deliberation over how to solve the problem, I chose to have a Mercedes dealer replace my SBC unit that had hit its activation threshold. I just placed a call to the dealer that performed the work. I will report back on how it goes.
DasGeld, I think I saw you ask about timing on about when the service threshold might trip. Mine hit at about 95,000 miles.
Old Sep 20, 2018 | 11:01 AM
  #32
dsimms's Avatar
2006 CLS500
I had my main SBC unit and the brake light switch replaced over the last two years. Here's some info over at benzworld, including my posted experience:
https://www.benzworld.org/forums/w21...-25-years.html
Old Feb 1, 2020 | 06:28 PM
  #33
James Cruz's Avatar
2005 E55 and 2004 SL55
Old post, but this is true. However, I think it's for teh ABC though. Will be looking for my warranty we received in the mail.
Old Feb 28, 2020 | 08:50 PM
  #34
AMGfan84's Avatar
2012 W204 M272 2005 W211 E55
I have access to developer mode and was going through it today with out making any changes. I would actually like to exceed the threshold so i can set a fault code and have it replaced earlier for piece of mind. Does anyone know how to do this ? All the videos online are on how to reset it I want to do the total opposite.
Old Jan 3, 2025 | 06:43 AM
  #35
Marionator13's Avatar
Guys, I have an SL550 imported from the US into Bulgaria. Is this extended warranty valid for Europe too?
Old Jan 3, 2025 | 08:44 PM
  #36
mrvedit's Avatar
2004 SL600
I suspect it is only available to US dealers. Are you having problems now?
