SL55/63/65/R230 AMG: Sl55 tcu part number?
Old Sep 16, 2019 | 05:46 AM
Crossfit_SD's Avatar
e55 2004
Hi,
Could you please give me the part number of the sl 55 TCU ? Unable to find acurate info.
Can you confirm it has 2.82 gear ratio?
Old Sep 16, 2019 | 08:46 AM
cm60k's Avatar
03-08 SL55 comes with "2.82" for sure,
SL55 using many TCU #'s:-
032 545 35 32
034 545 10 32
035 545 16 32
035 545 19 32
003 446 41 10
depends to the Vin & TCU coding #'s of SL55 AKA M/Y's.
-;ZAYED;-
Old Sep 16, 2019 | 09:00 AM
e55 2004
032 545 35 32
034 545 10 32
035 545 16 32
035 545 19 32
003 446 41 10
-;ZAYED;-
Thanks a lot for your reply!
two more questions:
1- all these works with the 2.82 differential and all swapable between them?
2- how come that some of these tcu for instance 1032 is also marked for e55 when you do google search. The e model is 2.65 ratio.
Old Sep 16, 2019 | 09:59 AM
cm60k's Avatar
Yeah, diff. can be swapable to each other, i remember many E55 guys done it,
you will notice same part #, but can be used with multiple models, cause TCU # not always for specific model,
the difference with coding/file & DAS & fire-up through CAN,
can't use S55 or SL55 TCU into E55, due to differ DAS & fire-up,
TCU/EGS52 is kinda easy to program it or even change the Ratio, but need a qualified hand to deal with it, as coding it to VIN # that required,
as i know; you can change the Ratio with your current E55 TCU,,
no need to go with differ TCU for Ratio change..
-;ZAYED;-
Old Sep 16, 2019 | 10:12 AM
e55 2004
-;ZAYED;-
Oh i’m a bit confused now! So the tcu doesnt work in e55 even if it has sl55 dif?
I tought that TCu is differentiel related regardless of the car’s engine!
Old Sep 16, 2019 | 12:17 PM
cm60k's Avatar
You can simply put SL55 diff., and send your current TCU to a good tuner to change the Ratio from "2.65" to "2.82",,
you have TCU/EGS52, which is can be tuned & programmed to another Ratio (as required)..
-;ZAYED;-
Old Sep 16, 2019 | 01:42 PM
e55 2004
-;ZAYED;-
Ok, should this be done by star software?
I have a tcu for e500 2.82, can i use it or should it be an amg tcu?
Old Sep 16, 2019 | 01:56 PM
cm60k's Avatar
AFAIK, should be from your current AMG/K,
cause E500 TCU/file is differ, due to DAS/oil pressure/lock converter/ down shifts,,
change Ratio should be done properly via tuners, such as "EC/UPD/RENNtech/Kleemann/OE tuning"..
-;ZAYED;-
Old Sep 16, 2019 | 02:06 PM
e55 2004
-;ZAYED;-
No such tuners in my country but one of my mekaniks have an e55 tcu remaped for 2.82 differential. Cost 200$. Is it a good deal?
Old Sep 16, 2019 | 02:17 PM
cm60k's Avatar
Yeah, ($200) is kinda great for tuned M113K TCU..
-;ZAYED;-
