SL55/63/65/R230 AMG: Convertible hardtop isssue
Old Feb 22, 2020 | 07:22 PM
Brad61P's Avatar
2009 sl63 amg
After changing out the consumer battery (in the trunk), the hardtop open/close function stopped working on my 09 sl63 amg. Any ideas?
Old Feb 22, 2020 | 09:35 PM
seven_out's Avatar
SL500, Miata
Whether or not the "Easy Pack" feature works would be one clue to point you in the right direction.
Old Feb 23, 2020 | 10:22 AM
Brad61P's Avatar
2009 sl63 amg
The top is in the closed position, but have cycled the Easy Pack button.
Old Feb 25, 2020 | 11:47 AM
seven_out's Avatar
SL500, Miata
So, since the Easy Pack works, you know that the pump control relay and its fuse are good. And it's probably safe to assume the roof control unit is good. That would leave little or nothing else to consider besides the various limit switch inputs on the latches and such.
If you lack even a basic diagnostic reader, then you could access the connector to the roof controller, disconnect it, and then make continuity checks between the various sockets the inputs are wired to. Those checks are easily done, but getting the connector out might involve removing rear interior panels. Or not.
