SL55/63/65/R230 AMG: SL 63 Head Bolt Issue After 92k Miles?
Is there a consensus on whether or not this failure of the head bolts can happen at any time; or, if the car has 92k on it and they have not failed, then they are not going to? My heart loves this beast but but my head says be careful. Thank you in advance for your advice.
1- Drive the car and enjoy it without fussing about the bolts.
2- Replace the bolts one-by-one. Easy, fast and cheap.
3- Replace the bolts and headgasket following the official repair method. Expensive.
Personally I would not let this be a reason not to buy the car.
Good luck
64850 miles and counting, I don't have a price from my indie on the replacement cost, he's only ever done one, and the local dealer has never seen the problem, so, its probably less prevalent than some would say.
IMHO, it boils down to your intention with it. I purchased mine to hopefully keep it as a forever-car and went with the optimal solution: complete job with new OE gaskets, upgraded ARP head studs and SLS buckets.
The 1-by-1 method has a track record of working and was the plan for the winter, but my schedule didn't allow it. Currently have two active project cars in my garage so this went to a reputable shop.
If you are able to, pull the valve cover yourself and check. 11 years and 92K miles is a long time...maybe they were already changed.
Unfortunately, mine were original...silver lining is that I verified my cams were perfect, which was a motivator to go with the SLS buckets to protect them.
Let's be real, if spending a few thousand dollars on a repair is a deal breaker, you shouldn't be buying any late model exotic car.
The issues are rare? But....there are failures reported in a matter of a few weeks from a very small microcosm of owners on this forum. The issues are rare enough that there was a class action suite against MB years ago on the engine issues. It is also rare enough that owners who know the engines shortcomings are changing the head bolts as a preventative measure. Yep, sounds pretty rare.
Glad you love your M156 equipped SL. That's great. Best of luck to you. I personally love MB's. That's all I drive but I also know what AMG models/years I skipped and why. I have two AMG's and another on the way so, again, big fan here. Judging by the information readily available on this forum, maybe MBWorld should be accused of posting false information?
I guess the word common problems and rare can be used interchangeably:
https://blog.fcpeuro.com/mercedes-be...-common-issues
https://mbworld.org/how-tos/a/merced...roblems-386950
https://oppositelock.kinja.com/ama-a...tos-1791196192
Those idiotic hollow-torx bolts are used on the entire M112, M112K, M113 and M113K lines as well. However, it was the manufacturing defect with the anti-corrosive coating on a large batch of bolts used in the M156 that finally exposed bad design.
Every single older AMG engine has issues/areas to look out for. Research, prevent, maintain and enjoy.
The real shame is that if MB-AMG put a little more thought/QC into the head bolt and bucket designs, the M156 would have left the factory with a top end as bulletproof as its bottom end.
In any case, this woulda-shoulda-coulda discussion is circular as:
- These issues were corrected on later M156s.
- Reliability for anyone with an early M156 is easily achieved.
I'm a long time Porsche guy and saw the same thing with the 9X6 models which had issues with the IMS which could lead to engine failure. Lots of internet "experts" who loved to copy/paste information about the topic, but had no first hand knowledge of the issue or the cars. Meanwhile I've owned and wrenched on more than 10.
As for how Mercedes should issue a recall, perhaps so. I suspect that the number of failures are still low enough to not put them at risk of a successful class action lawsuit, and maybe below their internal threshold for a recall. Sadly you won't find a European car, especially a performance oriented one, that does not have some potential failure point(s). Fortunately this one can be repaired with relative ease.
I joined the forum for knowledge/sharing - how to repair what I have and for future purchases. I'm not an early adopter of new MB engines or technology and would rather learn more about the engines or tech before I purchase. That's not from being cautious; rather, it's from being burned. Again, there is a reason why I buy what I do and I learn from others mistakes. I read the negatives for what they are but, when you see consistent patterns, those negatives starting holding water. Even with the negative comments there is something to learn about the individual or experience. What's the saying - where there is smoke there is fire?
It was apparent many years ago the M156 had more problems than I was willing to tackle or to risk as a daily driver. Then again, that's when they were fairly new and I was not willing to take the chance with a very expensive car that had documented engine issues and not having a supply of engines to swap if I had a failure. It's not the only MB with serious issues but they were apparent early on and it kept me away, at the time, and on to the bi-turbo V12's for performance needs. The M156 engine issues don't make it a horrible engine but it does make them high risk if the problems are not fixed. If those looking to buy can't turn a wrench or afford to spend the additional money to rectify, it may be a bad choice and may make them stay away from the brand after their first experience. Then again, they may never have an issue but I would rather not throw caution to the wind.
To each their own and it is pretty obvious you absolutely love your M156's. As you can tell from my name, I prefer forced induction engines and that's the direction most manufacturers will take until they perfect the charging/storage of electric vehicles to meet the needs of distance drivers. I did research installing twin snails on the M156 since 4 valve heads take very well to forced induction. There is a company out in Cali, forgot the name, that installs twin snails on the SLS. When I contacted them about installing on other models, they declined and told me they only do the installs on the M159 SLS's. It's not that I never considered the M156. Just never considered without forced induction. If an engine is going to have risk of failure, I should get some serious power out of it to make it worthy my while.
Porsche owner here, continuously, for almost 30 years so I too am aware of that brand. Some issues may seem overstated but, even given that, there is still useful information being shared.
