SL55/63/65/R230 AMG: VVK -Coil overs and sway bars
Old Jun 18, 2020 | 10:03 AM
Jigginadeal's Avatar
2003 SL55
Guys,
Sean at VVK just received my 2003 SL55 at their shop in Stuart Florida. I'll be picking it up the first week in August, but that date is at my request not theirs. He'll be sending pictures as work progress and I'll post them here.
Old Jun 18, 2020 | 11:58 AM
HLG600's Avatar
2009 SL63 AMG
Interested to see the process. Will they be removing the ABC lines or just capping them off?
Old Jun 18, 2020 | 12:03 PM
2003 SL55
Coilovers and sway bars
It's an ABC delete so everything is coming out.
Old Jun 18, 2020 | 10:29 PM
Amir_AMG's Avatar
Veteran: Air Force
2000 SL500
Nice looking forward to pics and more reviews on it. I am definitely interested in the future
Old Jun 28, 2020 | 01:22 PM
NHSl550's Avatar
2007 SL65, 2009 SL550, 1991 SL500
Originally Posted by Jigginadeal
Guys,
Following.
Thinking of doing this to my 07 SL565
Old Jun 29, 2020 | 08:43 PM
C280 Sport's Avatar
MB’s of all kinds.
Excellent! This I am interested in. Looking at a SL55 but do not want to worry about ABC. My CL600 has ABC but has not been a issue and want to swap when the time comes. The SL55 I want to buy in the next few months hopefully. Only thing I want to know is can a I get ABC conversion done with no issues and a light fix. Good luck and keep us posted.
Old Jun 29, 2020 | 08:49 PM
2003 SL55
The light fix is easily handled at the dealership. I now wish I would have bought a really clean SL with a bad ABC system at a discount and then had it ripped out and coilovers and bars installed. I'll keep ya'll in the loop.
Old Aug 3, 2020 | 09:35 PM
2003 SL55
I'll be picking the car up over this coming weekend!!
Old Aug 4, 2020 | 08:01 AM
Amir_AMG's Avatar
Veteran: Air Force
2000 SL500
awesome! Post pictures and a review
Old Aug 4, 2020 | 06:01 PM
trabots's Avatar
2006 E55, 2006 SL55, 2006 LS7 Ute
That is not correct. Only a STAR with developer mode can code out the warning. No dealers have developer mode which can only be switched on by the factory. That is my information so far.
Old Oct 13, 2020 | 03:08 PM
BMHAN's Avatar
2015 S550 4Matic, 2005 SL65 AMG, 2008 CL65 AMG, 2006 Mini JCW GP, 2012 Mini JCW GP, 2011 AM Rapide
I'm trying to call Sean number but never reach him and the voicemailbox is full. Anybody can help me with this? I want to order the coil over for my 2005 SL65
Old Dec 22, 2021 | 04:09 PM
Tomcat SL's Avatar
2004 SL55 AMG
What ever happened to this project?
Old Dec 22, 2021 | 04:30 PM
BMHAN's Avatar
I got mine done 7 months ago. It took about 6 months from placing the order until we got it installed properly. But mine was SL65. The space for the front swaybar was very tight. VVK ended up need to custom fabricated the sway bar link for me. Sean was very helpful and it does not cost me extra. Just need to be patient. I am still waiting whether he will do the replacement pump for SL65. Mine still using tandem pump
Old Dec 22, 2021 | 04:42 PM
2003 SL55
Vvk Coilovers and Swaybars
So I had their complete system installed more than a year ago and have 10k miles or more on the car since then.
They were kind enough to do the install for me including completely removing the ABC system, and over all I feel it was money well spent. No more blowing hydraulic lines or sealing up leaks has made the car much more dependable.
It handles like it's on rails so no more over driving the steering system and all front plow is gone especially when in a high speed corner. It definitely feels more planted to the pavement even in the rain and gives me more confidence when flipping the car around on country backroads.
Two things I wish I could change though. There is some popping and knocking from the suspension when hitting bumps which I hear is typical when you switch to coilivers that is annoying, but to be completely honest I've not spoken with VVK about this so I can't fault them as perhaps there is something I can do about it here in Texas.
Also if i was to do this again I'd BE SURE to use a shock that I'd adjustable in both directions. The car rides pretty rough now and I think that would help some, but it probably doesn't help that I have this thing set down in the weeds. I do it again though!!
Old Dec 23, 2021 | 10:51 PM
LynnBilodeau's Avatar
SL55, Opel GT, 70 LT-1, BMW 745 turbo, MRoadster, 49 Stude truck, 69 Z/28, Ferrari project
I have an 04 SL55. The ABC was removed by a previous owner. It has coil overs with Bilstein struts. Also front and rear sway bars. I do not know if they used factory sway bars.
Guessing not, as the sway bar and hardware look exactly like this: https://www.ebay.com/itm/22196520034...kAAOSwJBdf06Pt
Rear sway bar clears everything with no issues. Front sway bar barely rubs the oil pan. I THOUGHT it was because the motor mounts needed replaced. I replaced both motor mounts and the trans mount after work this evening. The sway bar still barely rubs the oil pan. The sway bar mounts have about a 10mm spacer on each side between the mount and the chassis. I am planning to put another 1/8 inch spacer in there on each side, and hope that cures it. I don't think I have room for any more spacers.
Anyone else have an SL55 with coilovers and sway bars? I can take a pic of the sway bar tomorrow. Would like to know if it is a factory unit, or aftermarket.
I can start a new thread if needed, but thought it was right in line with the topic of this thread.
Old Dec 24, 2021 | 07:10 AM
BMHAN's Avatar
Guessing not, as the sway bar and hardware look exactly like this: https://www.ebay.com/itm/221965200348?epid=737786706&hash=item33ae282bdc:g: XAkAAOSwJBdf06Pt
you might want to get longer swaybar link. I have SL 65 so the space is much tighter. The link was extended by 1 inches
Old Dec 24, 2021 | 10:30 AM
Tomcat SL's Avatar
2004 SL55 AMG
I do not plan on slammin the car and I am looking at these shocks...do you see the adjustability you would be looking for?https://www.goldelementautoworks.com...s-r230-03-11-1
Old Dec 24, 2021 | 05:56 PM
Shimming both sides down another 3/16" got me the clearance I needed. Took it for a drive this afternoon. All good.
Old Jan 26, 2022 | 10:59 AM
Tomcat SL's Avatar
2004 SL55 AMG
Did you guys resolve the dash warning/light?
Old Jan 26, 2022 | 12:25 PM
2003 SL55
My red warning light is off and it never went to the stealership, so I don't know if totally gutting the ABC system shuts the light off but mine IS off. I have a white warning with the sos warning when I start the car which I dismiss.
I wish I could be of more help.
Old Jan 26, 2022 | 01:29 PM
cdk4219's Avatar
95 SL600
Pulling the ABC fuse takes the red light away, white light stays. Not sure if pulling the module will take the white away, but doubtful.
Old Jan 26, 2022 | 01:40 PM
2003 SL55
Nope my Module is gone and still have the white light. Its not an issue though I just dismiss it.
Old Jan 26, 2022 | 03:32 PM
Tomcat SL's Avatar
2004 SL55 AMG
Thanks...I'm taking it all in.
Old Jan 28, 2022 | 10:09 PM
trabots's Avatar
Just unplug the ABC module to put the light out permanently. You still get a warning at start up but a press of the LH up button gets you to your normal display.
Old Jan 29, 2022 | 06:32 AM
cnterline's Avatar
2003 SL55,2020 GTC ,2017 GTS sold ,2002 G500 Sold,2003 SL500 Sold,
Use star to say the car no longer has it
