SL55/63/65/R230 AMG: Spark Plugs
Old Nov 23, 2020 | 05:29 PM
6444johnf's Avatar
SL55
Spark Plugs
So I'm getting ready to replace my SL 55's spark plugs. Any thoughts on the correct plugs to use, NGK - Bosch - or ???
Old Nov 23, 2020 | 05:38 PM
marcd7tx's Avatar
E500 Wagon, SL63 IWC, E450 Wagon
I haven't worked on a 55 before, but if you don't go MB, make sure the dimensions of the aftermarket plugs are the exact same as MB OEM. It may be more of an issue in the DI engines where aftermarket plugs are sold to fit, but are a tad shorter in length. I ran across this working on M276 and 278 engines...
Old Nov 23, 2020 | 05:51 PM
6444johnf's Avatar
SL55
Thanks for your experience and your reply. Your help is appreciated
Old Nov 24, 2020 | 08:51 AM
HLG600's Avatar
2009 SL63 AMG
I've been using NGK plugs for the last decade across various platforms. Never an issue.
Also, this wrench is very helpful: https://www.fcpeuro.com/products/mer...n-wrench-2771z
Old Nov 24, 2020 | 08:59 AM
6444johnf's Avatar
SL55
Thanks for your insight!
Old Nov 30, 2020 | 09:39 PM
Swamp_Fox's Avatar
2007 SL65
I used NGK plugs on an M275 and talked to one NGK engineers before doing it. From my understanding they were the exact same plugs except for the branding on them. What difficulties did you have?
Old Dec 1, 2020 | 07:32 AM
6444johnf's Avatar
SL55
Thanks for your help. I'm planning at this point and gathering the necessary parts, so no problems! So has anyone had issues with the wires?
Old Dec 2, 2020 | 06:17 PM
euphoriaDSM's Avatar
SL65 AMG
NGK's all day and go a step colder than oem.
Old Dec 2, 2020 | 09:25 PM
Swamp_Fox's Avatar
2007 SL65
"A step colder" I had not heard to do that. What is the thinking in doing that.
Old Dec 4, 2020 | 05:44 PM
SL65 AMG
If you plan on doing any performance mods you'll want the colder plugs.
Old Dec 28, 2020 | 09:09 AM
WurlitzBurg's Avatar
2003 SL55 AMG
I used NGK Iridium IX LFR6AIX-11 (6619) OE on my '03 SL55. Great deals on ebay.
This would be a good time to also replace the valve cover seals, inspect the hoses, etc.
